Im using an AGSFeatureLayer with a Definition Expression.
My question: It's possible to get the AGSFeatureLayer.fullEnvelope synchronized?
After layerDidLoad (AGSLayerDelegate) is the fullEnvelope = nil, there is another delegate that can catch the the layer on an state in witch all features (from the Layer with the Definition Expression) were compleatly loaded?
Best Regards,
Cesar
You can listen for the AGSFeatureLayerDidLoadFeaturesNotification which gets fired by the AGSFeatureLayer whenever it fetches features from the service.
Here's a sample that shows how it is used -
Search Results for AGSFeatureLayerDidLoadFeaturesNotification · GitHub
Thank you Divesh for this answer. I think it's what im searching for. I can try it in a few minutes.
Best Regards,
Cesar
Pretty nice, that works easy!
Thank you!
