I wanted to load a shape file ,which is bundled along with my ipa , in my ESRI map. But on adding the AGSFeatureLayer ,created using the AGSShapefileFeatureTable, in the map's operational layers nothing happens .i used the same approach as in this sample code
https://developers.arcgis.com/ios/latest/swift/sample-code/feature-layer-shapefile/
When i tried the same shape file as a hosted feature layer and used AGSServiceFeatureTable to create AGSFeatureLayer it worked correctly.
I only have a developer license and when i tried the loadWithCompletion metod on the feature layer i got an error message license level has no permission to execute this feature.
To load a local shape file do i need any other higher license other than basic developer license ?
