Using the iPad ArcGIS app, updated to iOS 5 a new problem has come up. I have a map comprised off only my map services, in which i have a group of layers called "Environmental". The group is turned on but none of the layers inside of it are turned on. When the map first loads, every layer in that group turns on, causing problems obviously. They go away when I turn the group off however (even though individually they all say they are off). Anyone know whats causing this? This didn't happen with iOS 4, and isn't a problem on the arcgis.com viewer
-Paul
