Unable to reload base map with different geocode database
4572
11-20-2015 12:29 AM
RahulDev
I am downloading a geocode database  from web server, extracting the AGSFeatureTableLayers from it and adding on my base map.   But when trying to reload the map with different geocode database, the map doesn’t get reset and it displays the AGSFeatureTableLayers from previous geocode database.   When I relaunch the app it works fine.
DiveshGoyal
Have you tried calling AGSMapView#reset​ to clear the map view and then adding layers?​
RahulDev
Yes. Also tried to reinitialise the AGSMapView before reload but no effect. I can see the updated layers only after relaunching the app.
DiveshGoyal
Can you provide some code to reproduce this problem?
