Unable to load mmpk file in debug build using iPad.
928
05-31-2023 02:06 AM
funabiki
# Situation
  • When building with the simulator
    • When built from Xcode, it can load.
    • When the app is launched from the home screen, it cannot be loaded.
  • When building with the device
    • Cannot load either time.
# Device info
  • iPad Pro (11-inch) 2gen
  • iPad OS (15.0.1)
  • Xcode 14.1
# Library info
  • arcgis-runtime-ios (100.15.2)
# App stracture
This application uses a multi-module structure.
  • ArcGISAppKit // install arcgis-runtime-ios here
  • ArcGISApp
  • Pods
ArcGISAppKit/Package.swift
import PackageDescription
let package = Package(
    platforms: [
        .iOS(.v15)
    products: [
        // Products define the executables and libraries a package produces, and make them visible to other packages.
        .library(
            targets: ["ArcGISAppKit"]),
    dependencies: [
        .package(url: "https://github.com/esri/arcgis-runtime-ios", from: "100.15.2"),
        .package(url: "https://github.com/Esri/arcgis-runtime-toolkit-ios", from: "100.15.0"),
    targets: [
        .target(
            dependencies: [
                .product(name: "ArcGIS", package: "arcgis-runtime-ios"),
                .product(name: "ArcGISToolkit", package: "arcgis-runtime-toolkit-ios"),
        .testTarget(
            dependencies: ["ArcGISAppKit"]
# Affected code
// Called when ViewController is initialized
func load(mapPackage: AGSMobileMapPackage) async throws -> [AGSLayer] {
  try await mapPackage.load()  // an error occurs bud this method throws nothing
  guard mapPackage.loadStatus == .loaded else {
    throw .loadStatusError
  guard let mobileMap = mapPackage.maps.first,
              let layers = mobileMap.operationalLayers as? [AGSLayer] else {
                throw .noDataError
  mobileMap.operationalLayers.removeAllObjects()
  let groupLayers = layers.compactMap { $0 as? AGSGroupLayer }
  let featureLayers = layers.compactMap { $0 as? AGSFeatureLayer }
  try await groupLayers.asyncForEach { layer in
    try await layer.load()
  try await featureLayers.asyncForEach { layer in
    switch layer.name {
    case "DestinationPoint":
      let result = try await layer.featureTable?.queryFeatures(with: AGSQueryParameters())
      destinationPointLocationList += result?.featureEnumerator().allObjects.compactMap(\.geometry?.extent.center) ?? []
    default:
      break
  return groupLayers + featureLayers
# Errors output to console
2023-05-31 16:51:06.425313+0900 ArcGISApp[14607:3618492] Metal API Validation Enabled
2023-05-31 16:51:06.947983+0900 ArcGISApp[14607:3618492] ArcGIS Runtime Error Occurred. Set a breakpoint on C++ exceptions to see the original callstack and context for this error:  Error Domain=com.esri.arcgis.runtime.error Code=18 "Internal error." UserInfo={NSLocalizedFailureReason=Could not load Metal shader library from '/private/var/containers/Bundle/Application/93F38F17-7CA9-49ED-BA26-6AD3AB71015A/ArcGISApp.app/Frameworks/ArcGIS.framework/shaders/re_texture_draw_vs.metallib'. Message: library not found, NSLocalizedDescription=Internal error., Additional Message=Could not load Metal shader library from '/private/var/containers/Bundle/Application/93F38F17-7CA9-49ED-BA26-6AD3AB71015A/ArcGISApp.app/Frameworks/ArcGIS.framework/shaders/re_texture_draw_vs.metallib'. Message: library not found}
2023-05-31 16:53:27.197459+0900 ArcGISApp[14607:3618602] XPC connection interrupted
