Trouble with AGSAttachmentManagerDelegate
950
11-15-2012 12:29 PM
DanielMonego
I'm having some trouble with the AGSAttachmentManager downloading attachments. The following methods are all in a ViewController that implements AGSAttachmentManagerDelegate, but when it runs, the delegate methods don't fire. I've tried adding calls to retain, in case it was an issue with the manager getting prematurely cleaned up, but that doesn't appear to be what's happening. This happens with calls to a feature that definitely has an attachment visible in REST.
Is there a reason why the first function in this code would run but the second two wouldn't?
-(void)setSelectedGraphic:(AGSGraphic *)selectedGraphicValue
    _selectedGraphic = selectedGraphicValue;
    [self.relatedTableFeatureLayer clearAttachmentManagers];
    AGSAttachmentManager *am = [[self.relatedTableFeatureLayer attachmentManagerForFeature:_selectedGraphic] retain];
    am.delegate = self;
    [am downloadAttachmentInfos];
-(void)attachmentManager:(AGSAttachmentManager *)attachmentManager didDownloadAttachmentInfos:(NSArray *)attachmentInfos
    for(InspectionFormViewController *controller in self.viewControllers)
        controller.attachments = [NSMutableArray array];
    for(AGSAttachmentInfo *info in attachmentInfos)
        AGSAttachmentManager *am = [[self.relatedTableFeatureLayer attachmentManagerForFeature:self.selectedGraphic] retain];
        am.delegate = self;
        [am downloadAttachmentDataForId:info.attachmentId];
    //[attachmentManager release];
-(void)attachmentManager:(AGSAttachmentManager *)attachmentManager didDownloadDataForAttachment:(AGSAttachment *)attachment
        [controller.attachments addObject:attachment];
DiveshGoyal
Can you try doing this :
        [attachmentManager downloadAttachmentDataForId:info.attachmentId];
