Trouble accessing the ArcGIS module
2446
05-01-2017 09:42 AM
AylaPerry1
I've been struggling with installing and accessing the runtime SDK for iOS package in my Xcode files. For a brief 10 minutes I successfully got the import ArcGIS command to work properly, then I changed something and now it's not working anymore. Any ideas on how to remedy this issue? Thanks.
YueWu1
by Esri Regular Contributor
Hi Ayla Perry,
Which version of iOS are you working with? Is it a 10.2.5 or 100.0?
If it is 100.0, follow this:
I would recommend you can try to install our SDK by using CocoaPods. Have you followed our documentation about how to install the SDK?
Install and set up—ArcGIS Runtime SDK for iOS | ArcGIS for Developers
I assume you are using the manual way to install the SDK, then the tricky part is make sure the ArcGIS resource bundle point to the right path in your mac. Please check this part in our online install page:
Add ArcGIS resource bundle
If it is 10.2.5 follow this:
Add dependencies
Hope this can help.
AylaPerry1
I am using 100.0, and I have followed the manual way. It worked for a short amount of time and then stopped working. I am unfamiliar with CocoaPods so I haven't tried that way. The documentation wasn't very clear for me.
Thanks for your help though!
Brent_Michalski
If you just install the SDK via CocoaPods, it does NOT find the bundle.  The script is still looking for it in the users Library directory...
error: /Users/brent/Library/SDKs/ArcGIS/iOS/Frameworks/Static/ArcGIS.framework/Versions/Current/Resources/ArcGIS.bundle: No such file or directory
GagandeepSingh
Do you mean the import statement is returning an error? Or the map is not rendering?
AylaPerry1
the import statement is returning an error saying no module found. I've found a solution by adding the ArcGIS.framework directly to my project, via file > add files to 'project' > navigating to where I have the SDK stored and adding the ArcGIS.framework file. I've also added the ArcGIS.bundle, but adding the framework seemed to remedy the error message.
