Tiled map servics - How does it work ?
1457
10-23-2012 10:16 PM
AndrzejGórski
I have tile map service with some tiles defined like below (part):
level = 4; scale = 500000;
level = 5; scale = 250000;
level = 6; scale = 100000;
When I am zooming near scale 250000 or exactly zoom to scale 250000 i see that map requests for tile 6 !! with is defined for scale 100000. I checked with other scales and tile's level is always one more than I would expected.
After some tests I noticed that on iPads (no matter which version) inluding simulator requesting tile level is 5 - and that is ok. But on all iPhones (except iphone5 - didn't test) including simulator requesting level is still 6. There must be some error in SDK.
It can be easily verified even on sample attached to installation package of SDK for iOS.
Does anyone know why is it happen ? Any ideas ?
best regards
Andrzej
NimeshJarecha
Are you measuring map scale from self.mapView.mapScale property?
The map scale is different on the device then what you've set in the tiled map service. It is directly proportionate to the dpi/ppi. Your tiled map service scale are calculated at 96 dpi but your iPhone and iPad dpi/ppi are 163 (non-ratina) and 132 (non-ratina) respectively. So the map scale on iPhone and iPad are "scale on level * 163/96" and "scale on level * 132/96" respectively.
If you set layer's renderNativeResolution property to YES then it's going to be "scale on level * 326/96" and "scale on level * 264/96".
So the request are being sent accordingly.
Hope this helps!
Regards,
Nimesh
AndrzejGórski
hello again,
after many hours wasted�?�
I Have defined tiles like below
* level = 3; scale = 1000000;
* level = 4; scale = 500000;
* level = 5; scale = 250000;
* level = 6; scale = 100000;
I tested the same app on iPhone and on iPad requests which are generating when map scale is changing, and results are very strange:
a) iphone
tiles for level 4 were requesting when scale was
to: 636719
tiles for level 5 were requesting when scale was
to:  297136
tiles for level 6 were requesting when scale was
to: not checked
b) ipad/ iPhone sim on ipad
to: 515626
to: 240626
to: not checked
is it possible, that there are any parameter in map control or tile layer (or somewhere else)  which default value is incorrect and must be set to correct one? or is this just bug ?
best regards
Andrzej
NimeshJarecha
Hope this helps!
Regards,
Nimesh
AndrzejGórski
Hello Nimesh,
Few days ago I discovered relationship between scale (mapView.mapScale) and  service/device resolution ratio !! But I wasn't sure if I was wrong or right. So Your answer is great confirmation of my thoughts and work.
Thanks again and best regards
Andrzej
