text on sketch or graphics layer
4870
7
10-31-2012 01:55 PM
HamzaHaroon
Is it possible to put word text on a sketch or graphics layer? Or would i have to take the text and make some sort of custom graphic out of it and then place that on the graphics layer?
NimeshJarecha
Here is sample code, how to create a composite symbol with text/fill symbols and create a graphic with it.
AGSTextSymbol *textSymbol = [[AGSTextSymbol alloc]init]; textSymbol.textTemplate = @"Text Symbol"; textSymbol.color = [UIColor orangeColor];   AGSSimpleFillSymbol *simpleFillSymbol = [AGSSimpleFillSymbol simpleFillSymbol]; simpleFillSymbol.outline.color = [UIColor greenColor]; simpleFillSymbol.style = AGSSimpleFillSymbolStyleSolid;   //create a composite symbol AGSCompositeSymbol *compositeSymbol = [AGSCompositeSymbol compositeSymbol]; [compositeSymbol.symbols addObject:simpleFillSymbol]; [compositeSymbol.symbols addObject:textSymbol];  AGSGraphic *graphic = [AGSGraphic graphicWithGeometry:<your polygon geometry> symbol:compositeSymbol attributes:nil infoTemplateDelegate:nil];
Hope this helps!
Regards,
Nimesh
NimeshJarecha
You should use AGSCompositeSymbol for the graphic which will have AGSTextSymbol with Marker/Line/Fill symbol.
Regards,
Nimesh
HamzaHaroon
can you provide an example of how AGSTextSymbol can be used? I tried searching online, but couldn't find any.
NimeshJarecha
Hope this helps!
Regards,
Nimesh
HamzaHaroon
thanks alot. this definitely seems like what i need. One thing i cant figure out is if I can make the text wrap around underneath if its too long.
NimeshJarecha
No, unfortunately, you can't wrap around text.
Regards,
Nimesh
HamzaHaroon
oh ok. your code sample works great.
just some minor fixes to it:
textSymbol.text should be textSymbol.textTemplate
and [compositeSymbol.symbols addObject...]
NimeshJarecha
Thanks for pointing that out. I fixed it in my post.
Regards,
Nimesh
