Standard Licensing using in-house ArcGIS Server
1677
05-30-2014 11:55 AM
mikedavis2
I'm preparing to set up our first app using licensing at the standard level.  All the examples and demo apps make reference to using arcgis.com or an in-house portal for this, but we don't have a portal set up.
I think I remember hearing at the Dev Summit that it would be possible to perform the licensing against an ArcGIS server without the portal component - is this true?  If so do I need to do anything differently from the examples?
Thanks!
DiveshGoyal
If you don't have a portal, you can license your app at the standard level through a license code.
More info here - https://developers.arcgis.com/ios/guide/license-your-app.htm#ESRI_SECTION2_8F2F5E45D3294F1880F75177B...
Unfortunately, licensing an app based on a user logins is only available for on-premise ArcGIS portals, or ArcGIS Online Organization subscriptions.
DiveshGoyal
