SkechLayer load down tiled Map
1346
05-02-2012 05:41 AM
LucaAlferi1
Hi
In my application i use different base map. When application is loaded for the first time, skechLayer draw up tiled map (OK), but when i change the base map the skechLayer draws down the tiled map.
i used this code:
AGSGraphicsLayer* graphicsLayer2 = [AGSGraphicsLayer graphicsLayer];
[self.mapView addMapLayer:graphicsLayer2 withName:@"Graphics Layer 2"];
    self.sketchLayer = [AGSSketchGraphicsLayer graphicsLayer];
    [self.mapView addMapLayer:self.sketchLayer withName:@"Sketch layer"];
Why?
Help me please
NimeshJarecha
How you are changing the base map? You should use AGSMapView's insertMapLayer:withName:atIndex: method and insert base layer at index 0.
Regards,
Nimesh
NimeshJarecha
Regards,
Nimesh
LucaAlferi1
How you are chaining the base map? You should use AGSMapView's insertMapLayer:withName:atIndex: method and insert base layer at index 0.
Regards,
Nimesh
Grazie Grazie Grazie (Thanks Thanks Thanks)
it now works fine
