removeMapLayerWithName
3177
5
07-12-2011 09:48 AM
MarcoBrugna
Hi everyone,
I'm trying to remove a layer using the 'removeMapLayerWithName' function, but I receive the following error:
'Cannot remove an observer <AGSDynamicMapServiceLayer 0x541dde0> for the key path "dpi" from <AGSDynamicMapServiceLayer 0x541dde0> because it is not registered as an observer.'
Anyone knows how to solve it?
Marco
NimeshJarecha
Marco,
Thank you for reporting. We'll look into it.
Appreciate, if you can attach a sample app demonstrating the issue.
Thank you!
Regards,
Nimesh
DastanTashimbetov
Did you find solution?
DastanTashimbetov
Hi guys! In my case the problem was that It was not possible to subclass AGSDynamicMapServiceLayer. I don't know the reason for that (probably I miss something).
NimeshJarecha
If you want to subclass the dynamic layer then you should use AGSDynamicLayer(ForSubclassEyesOnly) .
Regards,
Nimesh
DastanTashimbetov
Regards,
Nimesh
Thank you!
