Problem With Pin on the mapview
1162
03-25-2011 04:35 AM
Mdhanu
Hi Everyone,
I am new to this ArcGIS and this is my first post.So my problem is when the location like "California" given to the AGSLocator then it will  gives four points and the mapview displays four pins.But in MKMapView in iOS SDK gives only one point and shows only one pin. What is the problem with this locator.
Can anyone please help me on this.......
Thanks & Regards
Dhanu
StanislavGusakov
New Contributor II
I didn't get the question. What do you need exactly?
And post your code, please.
Mdhanu
My Question is whenever i will give the location name to the AGSMap view like "California" it will gives 3 or 4 pins.But I need only one pin like MKMapView.How can i achieve this.
Thanks in Advance.......
DiveshGoyal
Which geocoding service are you using with the AGSLocator?
Can you post the URL of that service?
I suspect you may need to tweek some properties while geocoding (such as the Minimum candidate score, etc), but I need to look at the service first.
Mdhanu
this is the URL....
http://tasks.arcgisonline.com/ArcGIS/rest/services/Locators/ESRI_Places_World/GeocodeServer
