Potential Bug in iOS SDK
3565
09-13-2014 03:00 PM
GrahamMueller
Hello, I believe I've found a bug in the iOS ESRI SDK. I'm not sure where the appropriate location is to post or ask about it. I'm hoping if not here, someone from here will be able to direct me as to where it should go. If this is the appropriate location, I can post in more detail. Thanks.
AsrujitSengupta
Log a case with ESRI Tech-Support and let them know about it.
GrahamMueller
Thanks, but where do I do that?
GrahamMueller
It appears that in order to do that, I need a "Customer Number" and Phone Number plus a pin. I'm not sure what ours is, so I don't think I can log it.
AsrujitSengupta
Move this thread to these groups ArcGIS Runtime SDK for iOSDevelopers
Maybe someone from these groups will be able to help you with the issue that you are observing or give you a better insight.
I would also suggest you to describe your observations with as much details possible here, so that in case its a known issue someone can help you here.
