No Network, load from local geodatabase
2290
05-20-2014 12:38 PM
VIKRANTKRISHNA
I am struggling to build the logic for relaunching the application (or initializing) from local geodatabase layers, when app got crashed or closed for some reason with no network availability.
I will really appreciate any help with this?
ShiminCai
Hi, my app always starts up offline if a local geodatabase exists. My local geodatabase is in the app's Documents folder and it loads local data or live data in the viewDidLoad method. Hope it helps. Regards, Shimin.
@property (nonatomic, strong) AGSGDBGeodatabase *geodatabase;
//in the viewDidLoad
NSString *gdbFilePath = [[FCNSWUtils documentsPath] stringByAppendingPathComponent:@"MyLocalDB.geodatabase"];
    if([FCNSWUtils fileExist:gdbFilePath])
        [self loadLocalData];
    else
        [self takeOnline];//load live data.
-(void)loadLocalData
    AGSGDBGeodatabase *gdb = [[AGSGDBGeodatabase alloc]initWithPath:gdbFilePath error:nil];
    self.geodatabase = gdb;
    ////Remove all live feature layers if any
    for (AGSLayer* lyr in self.mapView.mapLayers)
        if([lyr isKindOfClass:[AGSFeatureLayer class]])
            [self.mapView removeMapLayer:lyr];
    //Add local feature/table layers
    for (AGSFeatureTable* fTable in self.geodatabase.featureTables)
        if ([fTable hasGeometry])
            AGSFeatureTableLayer *ftl = [[AGSFeatureTableLayer alloc]initWithFeatureTable:fTable];
            ftl.delegate = self;
            [self.mapView addMapLayer:ftl];
    [self showEditsInGeodatabaseAsBadge:self.geodatabase];
ShiminCai
    else
VIKRANTKRISHNA
But How about localTileLayer?, Is it possible to store AGSLocalTiledLayer in the geodatabase as well?
VIKRANTKRISHNA
I found the solution Thanks, It generated tpk on device as well!!
