MGRS to Point Method does not work!
1549
03-25-2013 06:01 AM
adityamehta
i am trying to convert to a AGSPoint from a MGRS grid String. But the function -(AGSPoint*)pointFromMGRS:(NSString*)mgrs; does not return the point! It Crashes the App!
the Error is :
Assertion failed: (m_ptr), function operator->, file /Source/borg/share/SharedArcGIS/Include/GeometryXLib/PlatformBase.h, line 369.
i have tried to put the grid string in many different formats and also to supply the it as following:
AGSPoint *point2 =[geometryEngine pointFromMGRS:[engine mgrsFromPoint:point1 numDigits:9 rounding:NO addSpaces:YES]];
But still the app crashed!
Could you please help me with this!
Thank you
NimeshJarecha
Please post MSGR string and point you are using for both methods so I can look into it.
Regards,
Nimesh
adityamehta
Thank you Nimesh for replying.
Following is the coordinates and value for MGRS i am passing. When i try to get the value for mgrsFromPoint method i get "40R BN 38 09" and this is the same MGRS coordinate string i pass for the pointToMGRS method which again returns the above mentioned error!
AGSPoint *point=[[AGSPoint alloc]initWithX:54.4166351 y:24.4787678 spatialReference:self.mapView.spatialReference];
NSLog(@"%@",[engine mgrsFromPoint:point numDigits:2 rounding:NO addSpaces:YES]);
NSLog(@"%@",[engine pointFromMGRS:@"40R BN 38 09"]);
Note : I am using the ArcGIS Runtime SDK for iOS v 2.3.2 for my project. I even tried if this works in 10.1.1 but the same error came up. Please help.
Thanks and Regards
Aditya
NimeshJarecha
Thanks for the info. I'll look into it.
Regards,
Nimesh
NimeshJarecha
I confirm that this is a bug. We'll fix it in the future version of the SDK.
Regards,
Nimesh
