Is there any replacement for ImageryTileLayer?
2004
08-26-2022 07:42 AM
AndriyFedin
My fellow web developers use ImageryTileLayer from ArcGIS API for JavaScript. I was unable to find anything similar in iOS SDK. How do we replace ImageryTileLayer?
MichaelBranscomb
Esri Frequent Contributor
The equivalent in ArcGIS Runtime is the AGSImageServiceRaster class, which you display via the AGSRasterLayer class:
Add raster data | ArcGIS Runtime API for iOS | ArcGIS Developers
ArcGIS Runtime SDK for iOS: AGSImageServiceRaster Class Reference
ArcGIS Runtime SDK for iOS: AGSRasterLayer Class Reference
AndriyFedin
Hi, Michael!
Thank you for your reply!
I tried to use the AGSRasterLayer & AGSImageServiceRaster, but it doesn't work for me. When I use image service URL from the AGSRasterLayer example on github, it works fine, but when I try the URL my teammates use on the web with ImageryTileLayer, the layer is not displayed.
I also noticed, that the ImageServer info structure and attributes differ between these URLs.
example URL:
https://gis.ngdc.noaa.gov/arcgis/rest/services/bag_hillshades_subsets/ImageServer
URL we use: https://tiledimageservices.arcgis.com/P3ePLMYs2RVChkJx/arcgis/rest/services/GEBCO_2021_Bathymetry/Im...
So it brings us back to the original question: maybe I should use other layer class?
MichaelBranscomb
I just gave this a try with another Runtime SDK - .NET - and it worked fine. But I noted:
  • I did have to wait some time for the service to initially display.
  • It was necessary to zoom in beyond the layer full extent before the layer was noticeably visible, although you may know what you're looking for.
  • I'm currently using a Developer license (i.e. no license is set) - are you running in developer mode or have to set a license?
Map = new Map(BasemapStyle.ArcGISDarkGray);
ImageServiceRaster imageServiceRaster = new ImageServiceRaster(new Uri("https://gis.ngdc.noaa.gov/arcgis/rest/services/bag_hillshades_subsets/ImageServer"));
RasterLayer rasterLayer = new RasterLayer(imageServiceRaster);
await rasterLayer.LoadAsync();
Map.InitialViewpoint = new Viewpoint(rasterLayer.FullExtent);
Map.OperationalLayers.Add(rasterLayer);
Thanks
AndriyFedin
Hi, @MichaelBranscomb!
The URL in your code sample works for me too, but this one doesn't.
According to Nicholas-Furness in this answer, the issue is related to LERC format, which is not supported for visualization by the runtime.
