Is there a way to restrict geometry editing and only allow attribute edits?
964
8
09-26-2011 10:38 AM
MattMiley
Is there a way to restrict geometry editing and only allow attribute edits? I know you can limit what fields are editable, but is there a way you can restrict geometry editing? So the users can only query and update attribute fields?
Thanks
NimeshJarecha
Are you using popups? if yes, you can set AGSPopupInfo::allowEditGeometry to FALSE. Here is the editing sample with popups.
Regards,
Nimesh
MattMiley
I'm not a dev, can I disable geometry edits within the json text file?
NimeshJarecha
NO..
Regards,
Nimesh
DarrenMackiewicz
It seems that this has been changed and that allowEditGeometry on the popup has been depricated.
How can I disable editing on the popup in the 2.3 API?
NimeshJarecha
AGSPopup's allowEditGeometry is NOT deprecated.
Regards,
Nimesh
DarrenMackiewicz
But, we're using AGSPopupsContainerViewController, as is the sample you referenced.
Again - to outline the goal here -
When the graphic button is clicked, and the attributes are put into the new popup window, next to the attachment icon is the edit geometry icon. We (I) want to "disable" or "hide" the editgeometry icon.
-(void)mapView:(AGSMapView *)mapView didClickCalloutAccessoryButtonForGraphic:(AGSGraphic *)graphic{
    self.activeFeatureLayer = (AGSFeatureLayer*) graphic.layer;
    //Show popup for the graphic because the user tapped on the callout accessory button
    self.popupVC = [[[AGSPopupsContainerViewController alloc] initWithWebMap:self.webmap forFeature:graphic usingNavigationControllerStack:NO] autorelease];
    self.popupVC.delegate = self;
    self.popupVC.modalTransitionStyle =  UIModalTransitionStyleFlipHorizontal;
    //If iPad, use a modal presentation style
    if([[UIDevice currentDevice] isIPad])
        self.popupVC.modalPresentationStyle = UIModalPresentationFormSheet;
    [self presentModalViewController:self.popupVC animated:YES];
NimeshJarecha
You should change your code if you want to control that....
-(void)mapViewAGSMapView *)mapView didClickCalloutAccessoryButtonForGraphicAGSGraphic *)graphic{
AGSPopupInfo *popupInfo = [self.webMap popupInfoForFeatureLayer:self.activeFeatureLayer];
AGSPopup *popup = [AGSPopup popupWithGraphic:graphic popupInfo:popupInfo];
popup.allowEditGeometry = FALSE;
self.popupVC = [[AGSPopupsContainerViewController alloc]initWithPopups:@[popup]];
//self.popupVC = [[[AGSPopupsContainerViewController alloc] initWithWebMap:self.webmap forFeature:graphic usingNavigationControllerStack:NO] autorelease];
DarrenMackiewicz
Got it, with a couple small tweaks. Thanks!
