Is it possible to change layer visibility in a AGSDynamicServiceMapLayer?
1305
10-04-2010 02:18 AM
JavierAbadía_Miranda
I mean, changing visibility of the layers that are within each service.
DiveshGoyal
Yes, you need to set the visibleLayers property on AGSDynamicMapServiceLayer.
You'll see it in the MapViewDemo sample
self.dynamicLayer.visibleLayers = [NSArray arrayWithObjects:[NSNumber numberWithInt:2], nil];
ok... what is the relationship between self.dynamicLayer.visibleLayers and each layerInfo.visible property?
when I load the service (AGSDynamicMapServiceLayer), visibleLayers array is empty, but all layerInfo.visible attributes are set to true.
Is this property updated when I change the visibleLayers array?
Thanks
Thanks
ok, answer to my own questions:
- initially visibleLayers array is nil.
- each layer's visible property is the default visibility and doesn't change when you update the visibleLayers array
Is it correct? Thanks.
NimeshJarecha
Yes, correct!
