iOS SDK create AGSPolyline with tiled image
2213
6
08-30-2020 05:39 PM
AndrewRangel
Hello,
I am looking to create an AGSPolyline with a tiled image as the style. I see how you can pass in a symbol, but I don't see a symbol type where I can pass in an image.
Tags (1)
Nicholas-Furness
I'm not entirely sure what you mean. Could you provide a screenshot of what you're trying to achieve? Do you mean something like the picture stroke symbol described in the ArcGIS Pro documentation here?
AndrewRangel
Yes! Thank you for pointing out that link. That is exactly what I am looking for, but for the iOS SDK. There only seems to be a way to pass a dash style and a line color, but no deeper customizations.
Nicholas-Furness
Unfortunately, Runtime does not support this at present.
Although there's no API, I had hoped that you might be able to construct symbol JSON and have Runtime render it using AGSSymbol.fromJSON(), but I checked with the team and this particular capability is not yet implemented (Runtime supports most of what can be authored in Pro for line styles, except picture and gradient line symbols). I don't have an ETA for when it would be implemented but I'll make sure your comment is noted.
AndrewRangel
I appreciate the quick response and the information, thank you.
Nicholas-Furness
Actually, there is also this (Marker Symbol Placement), which I think is more powerful and useful than picture stroke symbols: Position and place marker symbol layers—ArcGIS Pro | Documentation
Unfortunately, Runtime doesn't support this yet either, but it is at least being considered. Would that work for you?
AndrewRangel
Yes that would be idea. We are looking to create custom lines like the ones below
