iOS 5 GM Seed/XCode 4.2
2782
10
10-10-2011 08:05 AM
JeremyBixby
I've just upgraded to iOS 5 GM seed and XCode 4.2.  I also upgraded the iOS SDK for ArcGIS Server from 2.0 to 2.01.  When I build (with iOS 5 as the base SDK) and run my app in the iPhone 5  simulator, the map service never displays.  It still works fine in the iPhone 4.3 simulator.  The base SDK at both the project and target levels is set to iOS 5; the deployment target is set to iOS 4.2.  Would this be a problem with the simulator?
NimeshJarecha
No problem, great, you figured everything out 🙂
