Interrogate Identity result offline
1050
02-19-2013 02:57 PM
AaronLipinski
I have on my device, the json result of an Identity query from an ArcGIS server map service.
The json contains entries with attributes and geometry rings.
Given a coordinate, I'd like to be able to find the entries in the json file whose geometry contains the coordinate.
Then from those entries I'd like to obtain interesting attributes.
Can this be done using the SDK?
NimeshJarecha
You can create geometry with JSON text and then use ASGGeometryEngine to find relations between geometries. See working with JSON and Geometry operations doc.
Regards,
Nimesh
