Identify
5907
12
11-21-2011 08:19 AM
CarlosIsaac_Cabrera
Hello All,
I am just seeking to get some general questions answered.  First of all I am using arcgis explorer online to configure my app and I have enabled pop ups.  I was wondering if there is a way to either have the previous type of identify capability in the new ArcGIS for IOS app or if I can somehow change the default nature of identify to correspond to a feature / feature layer.  I'm trying to avoid having to create a custom application if I don't have to.  Any and all help is much appreciated.
Example:  I want to identify a parcel and the default thing returned is the default Location pop-up:
SEE ATTACHED IMAGE.
I would like to have the pop up for parcel information to come up instead. Is this possible using arcgis explorer online / the default configuration?  In the video demo online its shows the ability to identify with a button in the ios app but the latest version does not have said button.  Either I have not enabled it or this has changed.
I'll also create a ticket for this so I can get help from the horses mouth :).
CarlosIsaac_Cabrera
Sorry, forgot to attach the image.
AliciaSoto
I was in the same boat as you until the kind people here on the forums helped me out.
Check out my post here http://forums.arcgis.com/threads/42283-iOS-app-Editing-JSON?p=147560#post147560
RussRoberts
Esri Notable Contributor
If you tap on the default location popup you will open up a custom popup with the parcel information. The white arrow is a disclosure button and will appear when there are popups available where the pin has been dropped.
Hope this helps
Russ
CarlosIsaac_Cabrera
Hope this helps
Russ
Russ,
I figured this part out.  I want to avoid users having another step.  I want to be able to set the default pop up to the information of my choosing.
RussRoberts
To get that functionality to open the popup directly on the tap of a feature will require custom development. On the iPad version however the popup will open directly when you tap on the feature.
Russ
CarlosIsaac_Cabrera
Russ
That is good news.  We do have IPads to test with.  I guess I might have to create an app.  Thank you.
RussRoberts
Not a problem.
Cheers
Russ
CarlosIsaac_Cabrera
Did ESRI take the identify ability out of the new version of the default IOS app?
http://www.youtube.com/watch?feature=player_detailpage&v=HrX03Q8FElo#t=150s
RussRoberts
To identify a feature you need to enable pop-ups on your web..or if you are using your mobile content server you will need to write your popup-infos into the JSON. You cannot identify a feature without popups being enabled.
Russ
