How to use ENCMarinerSettings to set depth units with iOS/Swift
5156
15
01-14-2024 08:23 AM
ChrisPelon
Can someone help me set the depth units to feet? Here's my code, I am displaying the ENC chart successfully.
import SwiftUI
import ArcGIS
struct ContentView: View {
    @State private var map = AGSMap(basemapStyle: .arcGISOceans)
    var body: some View {
        MapView(map: map)
            .edgesIgnoringSafeArea(.all)
            .onAppear {
                map.initialViewpoint = AGSViewpoint(latitude: 45.318063, longitude: -85.2584, scale: 30055)
                loadENCExchangeSet()
    private func loadENCExchangeSet() {
        let depthUnits = AGSENCMarinerSettings.shared()
        // Load ENC Exchange Set
        if let catalogURL = Bundle.main.url(forResource: "CATALOG", withExtension: "031", subdirectory: "/ENC_ROOT") {
            let encExchangeSet = AGSENCExchangeSet(fileURLs: [catalogURL])
            encExchangeSet.load { error in
                if let error = error {
                    print("Error loading ENC Exchange Set: \(error.localizedDescription)")
                } else {
                    let encLayers = encExchangeSet.datasets.map { AGSENCLayer(cell: AGSENCCell(dataset: $0)) }
                    DispatchQueue.main.async {
                        self.map.operationalLayers.addObjects(from: encLayers)
                        // Adjust this viewpoint to match where your ENC data is
                        self.map.initialViewpoint = AGSViewpoint(latitude: 45.318063, longitude: -85.2584, scale: 30055)
        } else {
            print("Error: CATALOG.031 file not found in bundle.")
struct MapView: UIViewRepresentable {
    let map: AGSMap
    let graphicsOverlay = AGSGraphicsOverlay()
    func makeUIView(context: Context) -> AGSMapView {
        let mapView = AGSMapView()
        mapView.map = map
        mapView.graphicsOverlays.add(graphicsOverlay)
        return mapView
    func updateUIView(_ uiView: AGSMapView, context: Context) {
        // Perform any necessary updates to the UIView
struct ContentView_Previews: PreviewProvider {
    static var previews: some View {
        ContentView()
rolson_esri
Esri Alum
The API has changed. Load doesn't take a completion block like the 100 SDK. The Swift SDK was redesigned from the ground up to take advantage of all the features of swift, including Swift Concurrency.  That means that loading an exchange set is now an async method:
try await encExchangeSet.load()
adding operational layers is also different. There are add methods directly on the map (see doc here) .
So that code should probably look something like:
self.map.addOperationalLayers(encLayers)
rolson_esri
Esri Alum
BTW, as you migrate from 100 to 200 here is a doc that might help: https://developers.arcgis.com/swift/reference/migrate-from-100-x-to-200-x/
ChrisPelon
Thank you! This was the info I needed.
rolson_esri
Esri Alum
Can you please let me know if the depth units still don't work for you after you migrate your code? Thank you.
ChrisPelon
Depth units are now working as expected in 200 and the updated code. Thanks!
rolson_esri
Esri Alum
Also, @ChrisPelon, what version of 100.x are you using?
