How to transform the height of WGS 84 into DHHN2016
873
04-09-2022 03:15 PM
fedotevseev
Hi, everybody
Faced with the task of transforming the height in the arcgis runtime ios sdk from wgs84 to dhhn2016, I did not find a solution in the documentation, maybe someone will share ideas on how to do it. Thanks!
WGS84 EPSG Code 115700
DHHN2016 EPSG Code 7837
DiveshGoyal
Using GeometryEngine.project() should be able to take care of that
Just ensure the input and output spatial reference have the appropriate vertical coordinate system set.
