Why the transformation of the z-coordinate of the AGSPoint from one Spatial reference to another does not work
1741
04-09-2022 03:27 PM
fedotevseev
Hello everyone, please tell me why the transformation of z coordinates does not work x and y values changes, but z coordinate not change, I need the z coordinate to change according to the specified height of the vertical spatial reference, maybe I'm using the wrong tool for this?
an example of the code that I use:
let point1 = AGSPointMake3D(48.8589505, 2.2768487, 698.458, 0, .wgs84()
let transform1 = AGSGeometryEngine.projectGeometry(point1 as AGSGeometry, to: translate.inputSpatialReference)
let transform2 = AGSGeometryEngine.projectGeometry(point1 as AGSGeometry, to: translate.outputSpatialReference)
let transform3 = AGSGeometryEngine.projectGeometry(point1 as AGSGeometry, to: dhhn)
let transform4 = AGSGeometryEngine.projectGeometry(point1 as AGSGeometry, to: .webMercator())
print in concole:
Optional(AGSPoint: (48.858930, 2.276841, 698.458000, 0.000000), sr: 4269)
Optional(AGSPoint: (48.858951, 2.276849, 698.458000, 0.000000), sr: 4152)
Optional(AGSPoint: (48.858951, 2.276849, 698.458000, 0.000000), sr: 4258)
Optional(AGSPoint: (5438953.490354, 253524.372136, 698.458000, 0.000000), sr: 3857)
DiveshGoyal
Make sure the spatial references you are using are created with a vertical WKID that specifies the vertical coord system. https://developers.arcgis.com/ios/api-reference/interface_a_g_s_spatial_reference.html#ae1b20d3100e7...
You can check if your spatial references have a vertical component using the hasVertical property
https://developers.arcgis.com/ios/api-reference/interface_a_g_s_spatial_reference.html#a0e0bd2138b15...
fedotevseev
Yes spatial references have a vertical wkid, I'm testing to two spatial references
first: wkid 4326
verticalWKID 7837
results z-coordinate 562.5691528320312
second: wkid 4326
verticalWKID 0
but result z coordinate for different spatial references is the same
DiveshGoyal
Are these the input spatial reference? Or the target?
can you provide WKID and verticalWKID of both input and target spatial references, along with the coordinates you are projecting, and the results you are getting. We can try to repro on our end
It is very hard to piece together this information from your messages above
fedotevseev
My goal is to get the transformed height in DHHN2016 (verticalWkid 7837), from WGS 84 (verticalWKID 115700).
To do this, I created:
The result I am trying to get from converting the height of wgs 84 to the height of dhhn2016:
I probably don't use some additional transformation to achieve the desired result
