How to obtain dSYM file for ArcGIS.framework
1689
06-16-2025 06:09 AM
RoshaniBorse
I am uploading an iOS app to TestFlight that uses the ArcGIS Runtime SDK for iOS.
I received this error during upload:
The archive did not include a dSYM for the ArcGIS.framework with the UUIDs [A15E9813-DB01-31C5-9FBD-D9A344C80888]
How can I obtain the matching dSYM file for this version of the ArcGIS.framework?
Environment details:
  • ArcGIS SDK installed via CocoaPods
  • Pod: pod 'ArcGIS-Runtime-SDK-iOS', 100.14.1
  • Xcode Version: [enter your version here, e.g., Xcode 16.3]
  • Build settings: “DWARF with dSYM file” for both Debug and Release
PhilipGruenler
Hi RoshaniBorse,
Thanks for contacting us with your question. I have a couple questions. 1) If you look into your cocoapod source zip file, is the dSYM for ArcGIS.xcframework missing? When I looked into the cocoapod zip file I found a dSYM to go along with the ArcGIS.framework. When I run dwarfdump --uuid on the dSYM it reports the same UUID that you listed above. 2) I found a post on the Apple developer forum that talks about a new, Xcode 16 warning that sounds similar to what you are seeing. However, you said the missing dSYM causes an error and the post has it as a warning that can be ignored. Is this an error that is blocking you?
Phil
