How to group a field in *.geodatabase using `AGSQuery`?
1029
03-06-2019 05:36 AM
MuruganandhamKuppan1
I would to like to group a field from `geodatabase`. The desired query is,
SELECT PINCODE
FROM <table-name>
GROUP BY PINCODE;
How to create a `AGSQuery` object focusing above SQL Query?
I'm using ArcGIS runtime SDK 10.2.5.
This guide helped me explore more. The expected result should be like,
PINCODE: [
10002,
10004,
10007,
10022
But, I got as follows,
        PINCODE = 10002;
        "PINCODE_COUNT" = 147;
        PINCODE = 10004;
        "PINCODE_COUNT" = 198;
        PINCODE =10007;
        "PINCODE_COUNT" = 71;
The PINCODE 10002 has been holding by 147 records in the database.
NimeshJarecha
Can you please post your code here?
Regards,
Nimesh
