I have generated geodatabase on device for offline use. Now I want to get only those features which are last edited/modified or newly added instead of whole features data and update geodatabse(which will contain old + new feature data) on device when user press refresh button. Right now I am using Arcgis runtime iOS sdk v100.0
How I will achieve that thing?
Kamal
You'll have to loop through the tables in your geodatabase and use updatedFeaturesWithCompletion: method available on AGSGeodatabaseFeatureTable class. Alternatively, you can also just get the number of updates using updatedFeaturesCountWithCompletion: method.
Suganya
Thanks Suganaya.
Actually I want to fetch only updated features or specific features data from arcgis online layer url not from the locally geodatabase.
Kamal
Do you mean when you do a sync? If that's the case, by default sync operation is performed for only the changes.
Yes I am asking about sync operation. So one thing I want to confirm is that when I call feature service again then it will return only updated feature data or whole feature data?
Kamal
At least in my experience the default behavior when syncing is to send and receive only the diff information. You shouldn't be getting back the entire dataset.
