How to get AGSNMEALocation from AGSNMEALocationDataSource
1493
05-10-2021 10:13 AM
WyattHarrell
I am attempting to use the initializer initWithEAAccessory:protocol: and the locationDataSource:locationDidChange: method for the AGSNMEALocationDataSource.
 The documentation for AGSNMEALocationDataSource states that “the locationDataSource:locationDidChange: (AGSLocationChangeHandlerDelegate-p) method will return an AGSNMEALocation,” but after conforming to the AGSNMEALocationDataSourceDelegate the method actually returns a AGSLocation instead.
How can I access the AGSNMEALocation?
class SomeClassName: AGSLocationChangeHandlerDelegate {
    func locationDataSource(_ locationDataSource: AGSLocationDataSource, locationDidChange location: AGSLocation) {
        // This delegate method gives back an AGSLocation instead of the needed AGSNMEALocation as stated in the documentation
Ting
by Esri Regular Contributor
Hi Wyatt,
You can safely downcast the `AGSLocation` type to `AGSNMEALocation` with
```swift
guard let nmeaLocation = location as? AGSNMEALocation else { return }
Reason:
The NMEA delegate method inherits from the `AGSLocationChangeHandlerDelegate`... But I'll let our team know that the API design here is a bit confusing, and maybe we can add another `AGSNMEALocation` specific stub in the delegate.
References:
- Sample code
- AGSNMEALocation
Ting
Hi Wyatt,
```swift
Reason:
References:
- Sample code
- AGSNMEALocation
WyattHarrell
Thank you so much, I appreciate the help.
