How to add libAGSiPhone.a into iPhone OS Application Project??
2206
04-21-2010 10:14 PM
shinkookim
Hello, I installed ArcGIS API for iPhone SDK,
and I succeeded to show MapServives with ArcGIS Templates in XCode.
And, I just made Project with iPhone OS Application(View-Based) And I'd try to Add Map on the View.
So I Added frameworks which are QuartzCore, CoreLocation, CoreGraphics And libAGSiPhone.a.
But, Compiler says several errors which is
1. AGSiPhone.h : No such file or directory
2. Expected specifier-qualifier-list before 'AGSMapView'
If I write the code #import "AGSMapVIew.h", Compiler says same as upper massages.
How Could I make Project with iPhone OS Application(View-Based) to show Map on the View, properly.
Is there something else? to show Map on the View.
DiveshGoyal
Have you tried using an ArcGIS Project template instead of a standard iPhone template? The ArcGIS template will add the necessary ArcGIS libraries for you.
You can find more info here : http://help.arcgis.com/en/arcgismobile/10.0/apis/iPhone/concepts/index.html#/Creating_a_New_Xcode_Pr...
_
Divesh
shinkookim
I'm just wondering that how I can show a AGSMapView on the View without ArcGIS Templete.
In other word, My question is How I can make ArcGIS Templete?
However, WebSite You write above is very very helpful for me!!
Thank you for answer, Technobrat.
DiveshGoyal
If you don't want to use an ArcGIS project template, but instead want to use the ArcGIS SDK in a standard iPhone project template or an existing project  , the above link I provided contains information on which project settings to modify. See the Using iPhone Application Project Templates section.
_
Divesh
