How do I invoke the calloutDidClickAccessoryButton delegate method for..
1015
04-27-2010 12:25 PM
ChanceYohman
the AGSCalloutDelegate protocol?
DiveshGoyal
The calloutDidClickAccessoryButton is invoked by the framework when the user taps on the button in the callout. This is an indication that the user wants to see more details than available in the callout (which is space constrained).
Why do you want to invoke that method? You would typically only react to it being invoked.
_
Divesh
ChanceYohman
Improper wording on my part. I wanted to know what event invoked it. Your explanation helped.
How do I place a callout on a map?
DiveshGoyal
Most often, you would place graphics (AGSGraphic objects) in a graphics layer (AGSGraphicsLayer) that was added to the map. Graphics can have attributes that would be shown in the callout when a user taps on a graphic.
_
Divesh
ChanceYohman
Thanks Divesh.
I was able to test the AGSCallout class & AGSCalloutDelegate delegate completely once I figured out that AGSMapView has a AGSCallout property.  Attached is a modified version of the GraphicsDemo.
See Lines  141-184 & 272-296  in GraphicsDemoViewController.m.
