Getting layer ID of table in dynamic map service
1696
09-09-2011 04:17 PM
RobertMartin2
Hello,
I am trying to retrieve the layer ID of a non-spatial table in a dynamic map service. At the start of my app I am creating a dictionary of layer names and IDs by looping over AGSMapServiceLayerInfo objects. The table, however, is not included. (I imagine this is because it has no graphic component in the map view.)  Is there any built-in property or method I could use for this?
Thanks in advance,
Robert
NimeshJarecha
Yes, you should use AGSMapServiceInfo's tableInfos property which provides an array of AGSMapServiceTableInfo objects. You'll get table id from there.
Regards,
Nimesh
RobertMartin2
Doh! That was easy. Thank you Nimesh.
RickJones
Could I see a snippet of how this is done?
I've tried this:
    AGSDynamicMapServiceLayer* layer = [[AGSDynamicMapServiceLayer dynamicMapServiceLayerWithURL:[NSURL URLWithString:kWaterNetworkURL]] retain];
    layer.visibleLayers = [NSArray arrayWithObjects:[NSNumber numberWithInt:0], [NSNumber numberWithInt:1], [NSNumber numberWithInt:2], [NSNumber numberWithInt:3], [NSNumber numberWithInt:4], [NSNumber numberWithInt:5], nil];
    AGSMapServiceInfo* msi =  ((AGSDynamicMapServiceLayer*)layer).mapServiceInfo;
    NSLog(@"Tables belonging to service with 6 layers and 4 tables");
    for (int i=0; i < [msi.tableInfos count]; i++) {
        AGSMapServiceTableInfo* ti = [msi.tableInfos objectAtIndex:i];
        NSLog(@"%d: %@", i, ti.name);
[self.mapView addMapLayer:layer withName:layer.name];
No tables are listed.
RickJones
I changed my code to this:
    NSURL *url = [NSURL URLWithString:kWaterNetworkURL];
    AGSMapServiceInfo *msi = [AGSMapServiceInfo mapServiceInfoWithURL:url error:&error];
and it now lists tables.
NimeshJarecha
Glad you figured out! 🙂 you were trying to read information before it was available.
Regards,
Nimesh
