Get image for legend
2020
09-03-2012 01:08 AM
c_f_ong
Hello
I've been trying to show a legend with info from a AGSUniqueValueRenderer as follows:
            AGSUniqueValueRenderer *renderer = (AGSUniqueValueRenderer *)featLayer.renderer;
            int num = [renderer.uniqueValues count];
            for (int j = 0 ; j < num ; j++)
                LegendInfo *info = [[[LegendInfo alloc] init] autorelease];
                AGSUniqueValue *value = [renderer.uniqueValues objectAtIndex:j];
                if ([value.symbol isKindOfClass:[AGSPictureMarkerSymbol class]])
                    AGSPictureMarkerSymbol *pms = (AGSPictureMarkerSymbol *)value.symbol;
                    info.image = [pms swatchForGeometryType:featLayer.geometryType size:CGSizeMake(24, 24)];
                else
                    info.image = [value.symbol swatchForGeometryType:featLayer.geometryType size:CGSizeMake(20, 20)];
                info.name = value.label;
                [self.legendInfos addObject:info];
And to show the details in a table view. The 'value.label' is listed correctly. Images from AGSPictureMarkerSymbol do NOT appear but image from a AGSSimpleMarkerSymbol shows correctly.
Anyone knows how to make the images from AGSPictureMarkerSymbol to show correctly in a table view? The webmap is showing AGSGraphic using the correct symbols accordingly.
Thanks.
Rgds
Ong CF
c_f_ong
Hi Nimesh
I've used AGSPictureMarkerSymbol's image property but still its imageData was null. So I went back to the hosted feature service to reset the unique values again. And after that, AGSPictureMarkerSymbol's imageData is no longer null and can now be displayed in a legend.
Thanks.
Rgds
Ong CF
c_f_ong
Hello
I've checked for more details as follows:
            // Check the renderer of feature layer
            if ([featLayer.renderer isKindOfClass:[AGSUniqueValueRenderer class]])
                NSLog(@"AGSUniqueValueRenderer");
                        NSLog(@"j %d; label %@; AGSPictureMarkerSymbol", j, value.label);
                        info.image = [pms swatchForGeometryType:featLayer.geometryType size:CGSizeMake(8, 8)];
                        NSLog(@"symbol: %@", [value.symbol encodeToJSON]);
                    else
                        NSLog(@"j %d; label %@; NOT AGSPictureMarkerSymbol", j, value.label);
Notes:
1. For AGSPictureMarkerSymbol:
symbol: {
    angle = 0;
    color = "<null>";
    height = 12;
    imageData = "<null>";
    imageName = "<null>";
    type = esriPMS;
    width = 12;
    xoffset = 0;
    yoffset = 0;
2. For NON-AGSPictureMarkerSymbol:
symbol: {
    angle = 0;
    color =     (
        0,
        0,
        128,
        128
    outline =     {
        color =         (
            0,
            0,
            128,
            255
        style = esriSLSSolid;
        type = esriSLS;
        width = 1;
    rotateAroundOffset = false;
    size = 12;
    style = esriSMSDiamond;
    type = esriSMS;
    xoffset = 0;
    yoffset = 0;
So, it seems that AGSPictureMarkerSymbol is not returning an image unlike AGSSimpleMarkerSymbol. Is there any way to get the image for AGSPictureMarkerSymbol?
Thanks.
Rgds
Ong CF
NimeshJarecha
Why are you not using AGSPictureMarkerSymbol's image property?
Regards,
Nimesh
c_f_ong
Hi Nimesh
Thanks.
Rgds
Ong CF
NimeshJarecha
Glad to know that. Probabaly, null image was the reason for not generating swatch for picture marker symbol.
Regards,
Nimesh
