Get Graphic of GraphicsLayer Like on Android
3771
07-26-2013 06:57 AM
MariusGächter
Dear all
Is there a possibility to get a graphic near a point on a graphicslayer on IOS in a similar way as on Android?
Like so:
[ATTACH=CONFIG]26249[/ATTACH]
(java: int[] clickedGraphicIDs = this.graphicLayer.getGraphicIDs(x, y, 30, 1); )
Thanks very much
cheers!
ChristopherBarger
Hello,
If you are set up for touch events in an AGSMapView (AGSMapViewTouchDelegate), you can use the method
mapView:didClickAtPoint:mapPoint:graphics:
this will run any time you tap the AGSMapView. It will return graphics as well as the screen and map point that you tapped. You can then do something like this to get all the graphics registered from that tap:
NSDictionary *graphicsDictionary = graphics;//graphics being what is passed in by the method
NSArray *graphicsArray = [graphicsDictionary valueForKey:@"YourGraphicsLayerName"];
Hope this helps.
