free-form drawing
2431
03-08-2017 02:34 PM
FrederickLee1
Does ESRI have the ability to allow free-form drawing (a.k.a. 'doodling') within a layer?
That is, where the user's finger movement is recorded into a path as can be done within iOS's Core Graphics: var simplePath = UIBezierPath() ... etc.?
Scenario:  I wish to doodle annotations (drawing) on an overlay and be able to store & recover such doodle.
How would/could that be arranged?
RyanOlson1
Yes - you can use the AGSSketchEditor with the creation mode of
AGSSketchCreationModeFreehandPolyline or
AGSSketchCreationModeFreehandPolygon.
Here is a sample that is using vertex editing. But change the creation mode to one of the above (ie .freehandPolyline) and you can sketch lines on the map.
arcgis-runtime-samples-ios/SketchViewController.swift at master · Esri/arcgis-runtime-samples-ios · ...
FrederickLee1
Thanks for the quick response!
I'm going to play with this per your directive.
Ric.
RyanOlson1
1. AGSSketchEditor has a "style" property which has a "feedbackLineSymbol" property. You can set that to whatever line symbol you want. It defaults to a dashed symbol.
2. You can save the resulting geometry, which will be a Polygon or Polyline as JSON. They support AGSJSONSerializable. From there you can store it in user defaults or however you want. And then re-hydrate the geometry from JSON later.
FrederickLee1
Reference: ESRI's Sketch Example:
Environment: iOS/Swift 3.0+
I notice that no overlays are used in the sketch, which uses the AGSSketchEditor.
However I believe I need the use of a graphics overlay object to display historical sketches.
Hence I've added the following:
 private var myPolyLine:AGSPolyline?
 private var graphicsOverlay = AGSGraphicsOverlay()
1) Making a copy of the sketch as a 'geometry':
 @IBAction func clear() {
        self.myPolyLine = self.sketchEditor.geometry!.copy() as? AGSPolyline
        self.sketchEditor.clearGeometry()
2) Restoring the sketch after 'deleting' it:
case 3: // ...redraw
            let lineSymbol = AGSSimpleLineSymbol(style: .solid, color: UIColor.red, width: 3)
            self.graphicsOverlay.graphics.add(AGSGraphic(geometry: self.myPolyLine, symbol: lineSymbol, attributes: nil))
            self.mapView.graphicsOverlays.add(self.graphicsOverlay)
I needed to create a graphics overlay to display the copy.
I can see the buildup of graphicOverlays.
So once I don't need this copy, I should REMOVE this particular overlay.
That is, each overlay would contain a previously-copied sketch and hence,
I should discard these overlays once not needed.   Correct?
As for persistent storage: a AGSPolyline is an NSObject so I could serialize it for storage accordingly.
Is this the correct way for creating a persistent store of a sketch and handling old sketches via removing the overlays?
RyanOlson1
You don't need to copy the geometry, it's immutable.
GraphicsOverlays can be re-used, and you can remove/add graphics from them.
