framework not found ArcGIS
4342
7
11-14-2012 11:49 PM
tonylau
when i building my project,  throw a error.
[ATTACH=CONFIG]19315[/ATTACH]
anybody can help me?
thanks!!
AaronConnolly
thanks!!
I would guess that you either didn't set the Framework Search Path in your project's settings. It might be helpful for you to read through the "Configuring an Xcode Project" directions as closely as you can. The directions are very specific:
http://resources.arcgis.com/en/help/runtime-ios-sdk/concepts/index.html#/Configuring_an_Xcode_Projec...
It might also be worthwhile to re-read the installation instructions as well. Alternatively, you can take the MapDemo project that comes bundled with the installation and modify that for your needs.
Good luck
- Aaron
JeffGiesler
Does it happen when you build to the simulator and a device or just one or the other?  I had a similar problem when I upgraded my device to IOS 6.  When I set "Build Active Architecture Only" To yes then I was able to build.Cheers,Jeff
tonylau
Good luck
- Aaron
Hi Aaron, thanks your anwser.
Configuring is right, Framework Search Path was not wrong.
My agssdk version is 2.2.1.
Could i send my project to you for help me?
tonylau
Hi Jeff,
my simulator device is ios 5.1.
I had try to change "Build Active Architecture Only " to Yes ,but ......
tonylau
Detail message�?
Ld /Users/apple/Library/Developer/Xcode/DerivedData/mapDemo-aayfkhtdjypnxgbgijtkroktsdtp/Build/Products/Debug-iphonesimulator/mapDemo.app/mapDemo normal i386
    cd /Users/apple/WorkDocument/MacCode/mapDemo
    setenv MACOSX_DEPLOYMENT_TARGET 10.6
    setenv PATH "/Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/usr/bin:/Applications/Xcode.app/Contents/Developer/usr/bin:/usr/bin:/bin:/usr/sbin:/sbin"
    /Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/clang -arch i386 -isysroot /Applications/Xcode.app/Contents/Developer/Platforms/iPhoneSimulator.platform/Developer/SDKs/iPhoneSimulator5.1.sdk -L/Users/apple/Library/Developer/Xcode/DerivedData/mapDemo-aayfkhtdjypnxgbgijtkroktsdtp/Build/Products/Debug-iphonesimulator -F/Users/apple/Library/Developer/Xcode/DerivedData/mapDemo-aayfkhtdjypnxgbgijtkroktsdtp/Build/Products/Debug-iphonesimulator -F/Users/apple/Library/SDKs/ArcGIS -F/Users/apple/Library/SDKs/ArcGIS/Samples -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/ArcGIS.bundle -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/Classes -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/Resources-iPad -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/ArcGIS.bundle/Resources -F/Users/apple/Library/SDKs -F/Users/apple/Library/SDKs/ArcGIS -F/Users/apple/Library/SDKs/ArcGIS/Samples -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/ArcGIS.bundle -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/Classes -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/Resources-iPad -F/Users/apple/Library/SDKs/ArcGIS/Samples/MapViewDemo/ArcGIS.bundle/Resources -filelist /Users/apple/Library/Developer/Xcode/DerivedData/mapDemo-aayfkhtdjypnxgbgijtkroktsdtp/Build/Intermediates/mapDemo.build/Debug-iphonesimulator/mapDemo.build/Objects-normal/i386/mapDemo.LinkFileList -mmacosx-version-min=10.6 -Xlinker -objc_abi_version -Xlinker 2 -ObjC -all_load -framework ArcGIS -lstdc++ -fobjc-link-runtime -Xlinker -no_implicit_dylibs -D__IPHONE_OS_VERSION_MIN_REQUIRED=50100 -lstdc++ -lz -framework MediaPlayer -framework QuartzCore -framework CoreLocation -framework CoreText -framework MobileCoreServices -framework Security -framework UIKit -framework Foundation -framework CoreGraphics -o /Users/apple/Library/Developer/Xcode/DerivedData/mapDemo-aayfkhtdjypnxgbgijtkroktsdtp/Build/Products/Debug-iphonesimulator/mapDemo.app/mapDemo
ld: framework not found ArcGIS
clang: error: linker command failed with exit code 1 (use -v to see invocation)
tonylau
thanks all
i had found my error.
when i setup agsruntimesdk, it had not add arcgis.o file to my sdk filepath.
JeffGiesler
Can you upload your project or a sample of it.Cheers,Jeff
