Files missing from Online-Offline Editing Sample
2265
05-27-2012 10:50 PM
Chrisvan_Aart
Hi Guys,
For a client we are building a sketching app that has to work in online-offline modus.
The app needs to be able to start without contacting any feature layers.
The Online-Offline Editing Sample gives us clues how to work with feature layers in offline modus by loading the feature definition from local files.
In OnlineOfflineFeatureLayer.m there is
- (id)initWithURL:(NSURL *)url mode:(AGSFeatureLayerMode)mode online:(BOOL)online{
   if (self.bOnline)
        else {
            //restore features from saved feature store...
            NSDictionary *featureLayerDefinition = [self readFeatureLayerDefinition];
            NSDictionary *featureSetDictionary = [self readFeatureSet];
So the method readFeatureLayerDefinition is going to load a definition from a local file:
-(NSDictionary *)readFeatureLayerDefinition
    NSError *error = nil;
    NSDictionary *flDefinition = nil;
    NSString *filename = [self featureLayerDefinitionFilename];
    if ([[NSFileManager defaultManager] fileExistsAtPath:filename]) {
  NSString *flDefinitionString = [NSString stringWithContentsOfFile:filename encoding:NSUnicodeStringEncoding error:&error];
        flDefinition = (NSDictionary *)[flDefinitionString AGSJSONValue];
return flDefinition;
featureLayerDefinitionFilename reads:
static NSString *kFlDefinitionFileName = @"FeatureLayerDictionary";
This file (next to static NSString *kFeatureSetFileName = @"FeatureSet";) is missing from the sample project.
Can you send/put these files online?
Thanks!
Chris van Aart
2CoolMonkeys
RickJones
Those files are generated by the sample when you go offline.
Chrisvan_Aart
The point is that the app needs to coldstart in offline modus.
So it needs to work without ever contacting the ARCGis server
Do you have a sample of the contents of the files? Or can one extract the files from a feature layer of ARCGis server?
RickJones
I had to add .txt to the filenames to upload them.  They normally have no extension.
Edit: Of course, you can modify the onlineoffline class to use whatever path and filename you want.
KirstenBeyer
Hi Chris,
Did you find a solution to this problem?
We are also trying to create an ios app that works in offline mode, without contacting server.  We need code to read in/access the feature layer data.  We have imported .tpk files without problems, but the feature layer is more complicated.  Is there a way to bring in map package (.mpk) files, or another feature format, offline?
Thanks!
K.B.
LeiQingtian
I also have the same function is a FeatureLayer of how offline when custom and I do not know a friend you achieve.Can you tell me under realistic idea of �??�??it?Thank you very much!
