featureTemplatePickerViewController for offline layer
1084
09-12-2011 11:15 PM
hermancheah
Hi, extracting from the arcgis sample code there is a method that calling webmap for features
how do i not rellying on webmap but to get the feature from offline layer.?
If I would like to create a manual form
-(void)featureTemplatePickerViewController:(FeatureTemplatePickerViewController*) featureTemplatePickerViewController didSelectFeatureTemplate:(AGSFeatureTemplate*)template forFeatureLayer:(AGSFeatureLayer*)featureLayer{
    //set the active feature layer to the one we are going to edit
    self.activeFeatureLayer = featureLayer;
    //create a new feature based on the template
    _newFeature = [self.activeFeatureLayer createFeatureWithTemplate:template];
    //Add the new feature to the feature layer's graphic collection
    //This is important because then the popup view controller will be able to
    //find the feature layer associated with the graphic and inspect the field metadata
    //such as domains, subtypes, data type, length, etc
    //Also note, if the user cancels before saving the new feature to the server,
    //we will manually need to remove this
    //feature from the feature layer (see implementation for popupsContainer:didCancelEditingGraphicForPopup: below)
    [self.activeFeatureLayer addGraphic:_newFeature];
    //Iniitalize a popup view controller
    self.popupVC = [[[AGSPopupsContainerViewController alloc] initWithWebMap:self.webmap forFeature:_newFeature usingNavigationControllerStack:NO] autorelease];
    self.popupVC.delegate = self;
    //Only for iPad, set presentation style to Form sheet
    //We don't want it to cover the entire screen
    if([[UIDevice currentDevice] isIPad])
        self.popupVC.modalPresentationStyle = UIModalPresentationFormSheet;
    //Animate by flipping horizontally
    self.popupVC.modalTransitionStyle =  UIModalTransitionStyleFlipHorizontal;
    //First, dismiss the Feature Template Picker
    [self dismissModalViewControllerAnimated:NO];
    //Next, Present the popup view controller
    [self presentModalViewController:self.popupVC animated:YES];
    [self.popupVC startEditingCurrentPopup];
PaulLohr
Are you wanting to edit features that are stored locally on the iPhone or iPad?
Paul Lohr
Lohr Geospatial Services, Inc.
hermancheah
Yes, Paul, that is part of the things i need to work on the feature data will be store on an network server and local ipad.
