Feature Fields not editable in the AGSPopupInfo popup
2922
10
12-15-2011 05:32 AM
SeanTucker1
Question
- What Configuration of, Feature Service or code, allows Feature Fields to be editable in  AGSPopupInfo popup?
Problem
- Feature Fields do not show up in the AGSPopupInfo popup for editing.
Details
- the self.popupInfo.fieldInfos value shows up empty in the following code.
(void)mapView:(AGSMapView *)mapView didClickCalloutAccessoryButtonForGraphic:(AGSGraphic *)graphic
    //create a popup info object
    self.popupInfo = [AGSPopupInfo popupInfoForGraphic:graphic];
    //disable deleting and geometry editing
    self.popupInfo.allowDelete = NO;
    self.popupInfo.allowEditGeometry = NO;
    //create the popup container
    self.popupVC = [[[AGSPopupsContainerViewController alloc]initWithPopupInfo:self.popupInfo graphic:self.newFeature usingNavigationControllerStack:YES]autorelease];
    self.popupVC.delegate = self;
    //push the popup controller onto the navigation stack
    [self.navigationController pushViewController:self.popupVC animated:YES];
    //start editing mode
    [self.popupVC startEditingCurrentPopup];
NimeshJarecha
Let me ask few questions to narrow down the issue...
1. Is this a new graphic created or an existing graphic on the map?
2. Is this graphic belong to a feature layer?
3. Is this feature layer editable?
4. You are creating a popupInfo for 'graphic' in following code line...
but creating a popupVC for self.newFeature. Why?
Are you missing a code line? self.newFeature = graphic?
Regards,
Nimesh
SeanTucker1
Answers
1. New graphic
2. Yes the graphic belongs to a feature layer
3. The Feature Layer is Editable
    - Feature Access "Editing" selected in AGS Manager
4. Code should read "graphic" .. "graphic" ..
    I was trying "self.newFeature" .. "self.newFeature" first .. that did not work.
    It reads all "graphic". Either way does not work.
Thanks
Sean.
Regards,
Nimesh
NimeshJarecha
Since, it's a new feature, you MUST add it to the feature layer before creating a popupInfo. Are doing that?
[self.featureLayer addGraphic:graphic];
Regards,
Nimesh
SeanTucker1
Answer(s)
Yes - it is added to the feature layer before creating the popupInfo.
Thanks
Sean.
Regards,
Nimesh
NimeshJarecha
If possible, can you please share your sample application so I can test it?
Regards,
Nimesh
SeanTucker1
How do I do that?
NimeshJarecha
You can add attachment to the post here.
Regards,
Nimesh
SeanTucker1
Intranet AGS Server.
But if you test code against a working service on your side, let me know.
For your code .. Update
-incidentURL
-incidentLayer
SeanTucker1
See attached.
You will have to update
- "incidentURL"
