Error While going to Current Location
1008
08-05-2012 10:35 PM
KhurramWaqas
Hy I am using iOS Runtime SDK in my app. I am facing strange behavior of my app, When I go to Current Location then it does not show the current location and shows following errors in Output:
2012-08-06 10:58:00.970 AlMurshid[5154:5733] Error happened for tile 7/26143/21251
2012-08-06 10:58:01.892 AlMurshid[5154:5733] Error happened for tile 7/26213/21251
2012-08-06 10:58:01.894 AlMurshid[5154:5733] Error happened for tile 7/26212/21251
My code on GoToCurrentLoc button click is as:
[self.mapView.gps stop];
 self.mapView.gps.autoPan = AGSGPSAutoPanModeDefault;
 self.mapView.gps.wanderExtentFactor = 0.75; //75% of the map's viewable extent
 [self.mapView.gps start];
The same code was working fine a month before. please Guide me what's going wrong in it?
NimeshJarecha
The errors you see in the debug window are for fetching the tiles. Also, you are not able to see the GPS symbol. These indicates that there is a network issue. Check your wi-fi/3g connectivity.
Regards,
Nimesh
