drawStatusChangedHandler
2233
11-22-2016 07:10 AM
BrianFlood1
has the drawStatusChangedHandler block been removed at 100? thanks
RyanOlson1
It has been removed in favor of KVO on the `drawStatus` property:
import UIKit
import ArcGIS
private var myKVOContext = 0
class ViewController: UIViewController {
    let mapView = AGSMapView(frame: CGRect.zero)
    override func viewDidLoad() {
        super.viewDidLoad()
        mapView.frame = view.bounds
        mapView.autoresizingMask = [.flexibleWidth, .flexibleHeight]
        view.addSubview(mapView)
        mapView.map = AGSMap(basemapType: .streets, latitude: 0, longitude: 0, levelOfDetail: 0)
        mapView.addObserver(self, forKeyPath: "drawStatus", options: .new, context: &myKVOContext)
    override func observeValue(forKeyPath keyPath: String?, of object: Any?, change: [NSKeyValueChangeKey : Any]?, context: UnsafeMutableRawPointer?) {
        if context == &myKVOContext{
            if keyPath == "drawStatus"{
                print("drawStatus changed: \(mapView.drawStatus.rawValue)")
        else{
            super.observeValue(forKeyPath: keyPath, of: object, change: change, context: context)
RyanOlson1
import UIKit
import ArcGIS
        super.viewDidLoad()
        else{
BrianFlood1
thank you, works as expected
JamesRichards1
Brian,
If your going to be using KVO much, check out Facebook's KVOController library:
https://github.com/facebook/KVOController
It's block based API makes wiring up KVO events much cleaner in code.
Cheers,
James
BrianFlood1
thanks james, I'll take a look
