Hi,I'm using an identifylayer, with the controller. The identify itself works, the object is highlighted with a color, but...I have to tap the object twice before the callout is shown. So, summarized:First tap: Object is selected (Highlighted)Second tap: Callout is shownI want to skip the second step, but i have no idea how. I looked into the class reference, but... couldn't find anything...The code I use:- (void)mapView:(AGSMapView *)mapView didClickAtPoint:(CGPoint)screen mapPoint:(AGSPoint *)mappoint graphics:(NSDictionary *)graphics {
self.identifyParams.tolerance = 7;
self.identifyParams.geometry = mappoint;
self.identifyParams.size = mapViewController.mapView.bounds.size;
self.identifyParams.mapEnvelope = mapViewController.mapView.envelope;
self.identifyParams.returnGeometry = YES;
self.identifyParams.layerOption = AGSIdentifyParametersLayerOptionAll;
self.identifyParams.spatialReference = mapViewController.mapView.spatialReference;
//execute the task
[self.identifyTask executeWithParameters:self.identifyParams];
//results are returned
- (void)identifyTask:(AGSIdentifyTask *)identifyTask operation:(NSOperation *)op didExecuteWithIdentifyResults:(NSArray *)results {
//clear previous results
[mapViewController.identifyLayer removeAllGraphics];
_identifyInfoTemplate = [[IdentifyInfoTemplate alloc] init];
for (AGSIdentifyResult* result in results) {
result.feature.symbol = [self determineAndReturnSymbol:AGSGeometryTypeForGeometry(result.feature.geometry)];
result.feature.infoTemplateDelegate = _identifyInfoTemplate;
[mapViewController.identifyLayer addGraphic:result.feature];
//call dataChanged on the graphics layer to redraw the graphics
[mapViewController.identifyLayer dataChanged];
