Directories not found error for new ArcGIS for iOS app
3028
06-19-2012 06:21 AM
JohnMcleod1
Hello Everyone,
I'm new to ArcGIS for iOs so please be patient.
My current project involves an iOS 5 project with an ESRI map.
I downloaded and installed AGSRuntimeSDKiOSv2.2.1.pkg.
I have configure Xcode with the following...
  1. Added the appropriate frameworks within the project
  2. Added ArcGIS.bundle to project
I have also added the below search paths.
  • Other Linker Flags: -lstdc++ - framework -all_load -ObjC
  • Framework Search Paths: ${HOME}/Library/SDKs/ArcGIS
  • Library Search Paths: ${HOME}/Library/SDKs/ArcGIS/iOS.sdk/usr/local/lib
  • User Header Search Paths: ${HOME}/Library/SDKs/ArcGIS/iOS.sdk/usr/local/include
Although, when I go to the paths above in finder, I don't see "iOS.sdk/usr/local/lib".
When I try to build the project, I'm getting several errors.
It looks to me they are reference errors to the libraries.
Can anyone please help me with this?
Thank you,
John
NimeshJarecha
You should remove Library and Header search paths and make sure following is configured correctly.
Other Linker Flags: all_load -ObjC -framework ArcGIS
Framework Search Paths: $(HOME)/Library/SDKs/ArcGIS
Add following frameworks:
  • CoreGraphics.framework
  • CoreLocation.framework
  • Foundation.framework
  • QuartzCore.framework
  • UIKit.framework
  • CoreText.framework
  • libstdc++.dylib
  • MediaPlayer.framework
  • MobileCoreServices.framework
  • libz.dylib
  • Security.framework
Please refer this document for detail.
Regards,
Nimesh
NimeshJarecha
  • UIKit.framework
  • libstdc++.dylib
  • libz.dylib
Regards,
Nimesh
JohnMcleod1
Thank you for the reply.
I did what you suggested and no errors now.
I'm now getting a different problem.
New topic.
Thanks again,
John
