Custom google tile layer
3338
07-03-2013 11:35 PM
tomsonxu
Attached custom google tile layer codes work fine with Arcgis iOS SDK v2.x. When upgrade to SDK v10.1, compile error: AGSTileOperation and AGSTile not found. It seems that these class/protocol are removed from SDK v10.1. I have read custom tile layer sample at (http://www.arcgis.com/home/item.html?id=faab53d140e44c02941bf7deb30d7d18), but I don't know How to revise attached file to make it work in v10.1.
Any tips? thanks.
DavidLednik
Hi Tomson,
If you're accessing web tiled layer you can use 10.2.3: AGSWebTiledLayer Class Reference
It allows you to pull in tiled layer by providing correct URL template.
In your case that would be:
http://mt{subDomain}.google.cn/vt/v=w2.114&hl=zh-CN&gl=cn&x={col}&y={row}&z={level}&s=
Regards,
David
