Crash on doneLoadingHandler
1109
05-22-2017 05:08 AM
AnkitShah
Crashed: com.esri.arcgis.agsoperationQueue.serial
0 libobjc.A.dylib 0x1801a80b0 objc_retain + 16
1 libobjc.A.dylib 0x1801a9f68 objc_retainAutorelease + 12
2 LAFDBrush_Prod 0x100587ba4 doneLoadingHandler + 28
3 LAFDBrush_Prod 0x100a4a4fc std::__1::__function::__func<RT_Layer_setDoneLoadingCallback::$_73, std::__1::allocator<RT_Layer_setDoneLoadingCallback::$_73>, void (void*, Esri_runtimecore::Mapping::Error const&)>::operator()(void*&&, Esri_runtimecore::Mapping::Error const&) + 56
4 LAFDBrush_Prod 0x100bb9764 Esri_runtimecore::Mapping::Delegate<Esri_runtimecore::Mapping::Loadable, Esri_runtimecore::Mapping::Error const&>::forward(Esri_runtimecore::Mapping::Loadable&, Esri_runtimecore::Mapping::Error const&) const + 396
5 LAFDBrush_Prod 0x100c13664 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_without_check_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 168
6 LAFDBrush_Prod 0x100af5904 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 180
7 LAFDBrush_Prod 0x100bb9090 Esri_runtimecore::Mapping::Data_source_layer::set_load_status_and_error_on_layer_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 168
8 LAFDBrush_Prod 0x100dcb058 std::__1::__function::__func<Esri_runtimecore::Mapping::Data_source_layer::set_data_source_(std::__1::shared_ptr<Esri_runtimecore::Mapping::Data_source> const&)::$_295, std::__1::allocator<Esri_runtimecore::Mapping::Data_source_layer::set_data_source_(std::__1::shared_ptr<Esri_runtimecore::Mapping::Data_source> const&)::$_295>, void (Esri_runtimecore::Mapping::Loadable const&, Esri_runtimecore::Mapping::Load_status)>::operator()(Esri_runtimecore::Mapping::Loadable const&, Esri_runtimecore::Mapping::Load_status&&) + 112
9 LAFDBrush_Prod 0x100dffb5c Esri_runtimecore::Mapping::Signal<Esri_runtimecore::Mapping::Loadable const, Esri_runtimecore::Mapping::Load_status>::operator()(Esri_runtimecore::Mapping::Loadable const&, Esri_runtimecore::Mapping::Load_status) const + 420
10 LAFDBrush_Prod 0x100c136a0 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_without_check_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 228
11 LAFDBrush_Prod 0x100af5904 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 180
12 LAFDBrush_Prod 0x100af5a70 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Loadable const&) + 92
13 LAFDBrush_Prod 0x100dffb5c Esri_runtimecore::Mapping::Signal<Esri_runtimecore::Mapping::Loadable const, Esri_runtimecore::Mapping::Load_status>::operator()(Esri_runtimecore::Mapping::Loadable const&, Esri_runtimecore::Mapping::Load_status) const + 420
14 LAFDBrush_Prod 0x100c136a0 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_without_check_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 228
15 LAFDBrush_Prod 0x100af5904 Esri_runtimecore::Mapping::Loadable::set_load_status_and_error_(Esri_runtimecore::Mapping::Load_status, Esri_runtimecore::Mapping::Error) + 180
16 LAFDBrush_Prod 0x100de9cb0 Esri_runtimecore::Mapping::Service_info_loader<Esri_runtimecore::Mapping::ArcGIS_map_service_info>::handle_response_(std::__1::shared_ptr<Esri_runtimecore::Mapping::Request> const&, unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 192
17 LAFDBrush_Prod 0x100c7f0f8 Esri_runtimecore::Mapping::Request_delegator::handle_response(unsigned long long, unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 416
18 LAFDBrush_Prod 0x100c7eef8 Esri_runtimecore::Mapping::Request::handle_response(unsigned char const*, unsigned long, std::__1::shared_ptr<Esri_runtimecore::Common::Client_reference> const&) + 136
19 LAFDBrush_Prod 0x1008054f4 RT_Request_handleResponse + 140
20 LAFDBrush_Prod 0x100576170 -[RTCRequest handleResponse:userDefinedError:error:] + 236
21 LAFDBrush_Prod 0x1006c9a10 __71+[AGSRTCRequestDispatcher ags_kickOffCoreRequest:forRequestDispatcher:]_block_invoke.173 + 1040
22 LAFDBrush_Prod 0x1006441a0 __38-[AGSObservableOperation didComplete:]_block_invoke + 264
23 LAFDBrush_Prod 0x1005b820c ags_runWithMainThread + 76
24 LAFDBrush_Prod 0x10064406c -[AGSObservableOperation didComplete:] + 280
25 LAFDBrush_Prod 0x10063facc -[AGSRequestOperation didComplete:] + 396
26 LAFDBrush_Prod 0x100643eac -[AGSObservableOperation finishWithResult:error:] + 148
27 LAFDBrush_Prod 0x100643188 -[AGSRequestOperation finishWithResult:error:] + 700
28 LAFDBrush_Prod 0x100643e08 -[AGSObservableOperation doCancel] + 72
29 LAFDBrush_Prod 0x10063f92c -[AGSRequestOperation doCancel] + 380
30 LAFDBrush_Prod 0x100662428 __40-[AGSOperationQueue cancelAllOperations]_block_invoke + 216
31 libdispatch.dylib 0x1805754bc _dispatch_call_block_and_release + 24
32 libdispatch.dylib 0x18057547c _dispatch_client_callout + 16
33 libdispatch.dylib 0x1805814c0 _dispatch_queue_drain + 864
34 libdispatch.dylib 0x180578f80 _dispatch_queue_invoke + 464
35 libdispatch.dylib 0x180583390 _dispatch_root_queue_drain + 728
36 libdispatch.dylib 0x1805830b0 _dispatch_worker_thread3 + 112
37 libsystem_pthread.dylib 0x18078d470 _pthread_wqthread + 1092
38 libsystem_pthread.dylib 0x18078d020 start_wqthread + 4
