Crash in iOS 11.1
11923
12-12-2017 05:01 PM
gautamsingh
Hi
After iOS 11 upgrade our few user's are facing crash in Map.We are using ARGIS-SDK 10.2.5.
Below is crash  log.
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
Triggered by Thread:  10
Filtered syslog:
None found
Thread 0 name:  Dispatch queue: com.apple.main-thread
Thread 0:
0   libsystem_kernel.dylib        0x0000000183d64c18 semaphore_timedwait_trap + 8
1   libdispatch.dylib             0x0000000183bf34d0 _dispatch_sema4_timedwait$VARIANT$mp + 84
2   libdispatch.dylib             0x0000000183bf3d40 _dispatch_semaphore_wait_slow + 72
3   QuartzCore                    0x00000001881f9964 native_window_begin_iosurface+ 768356 (_EAGLNativeWindowObject*) + 644
4   GLEngine                      0x00000001a464d1ec gliGetNewIOSurfaceES + 68
5   AGXGLDriver                   0x00000001a350b0b0 0x1a34f9000 + 73904
6   AGXGLDriver                   0x00000001a355b94c 0x1a34f9000 + 403788
7   AGXGLDriver                   0x00000001a3520aac 0x1a34f9000 + 162476
8   AGXGLDriver                   0x00000001a352462c 0x1a34f9000 + 177708
9   AGXGLDriver                   0x00000001a356b9cc 0x1a34f9000 + 469452
10  AGXGLDriver                   0x00000001a35151b0 0x1a34f9000 + 115120
11  GLEngine                      0x00000001a45820c8 glTexImage2D_Exec + 1732
12  OpenGLES                      0x000000018710d72c glTexImage2D + 108
13  IfosMobile Prod               0x0000000101ba1d5c Esri_runtimecore::HAL::Texture_ogl::init_+ 13868380 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<SkBitmap> const&, Esri_runtimecore::HAL::Texture_desc const&) + 504
14  IfosMobile Prod               0x0000000101ba146c Esri_runtimecore::HAL::Texture::create+ 13866092 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<SkBitmap> const&, Esri_runtimecore::HAL::Texture_desc const&) + 92
15  IfosMobile Prod               0x0000000101a73b94 Esri_runtimecore::Map_renderer::Image_drawable::Image_container::Chunk::texturize+ 12630932 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&) + 124
16  IfosMobile Prod               0x0000000101a7388c Esri_runtimecore::Map_renderer::Image_drawable::Image_container::draw+ 12630156 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::HAL::Tex_quad_shader_program> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&, bool) + 192
17  IfosMobile Prod               0x0000000101a73654 Esri_runtimecore::Map_renderer::Image_drawable::draw_+ 12629588 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties>, float) + 940
18  IfosMobile Prod               0x0000000101a3fd48 Esri_runtimecore::Map_renderer::Canvas_drawable::draw+ 12418376 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Drawable::Render_properties> const&, std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Display_properties> const&) + 68
19  IfosMobile Prod               0x0000000101a7dc44 Esri_runtimecore::Map_renderer::Map::draw+ 12672068 (std::__1::shared_ptr<Esri_runtimecore::HAL::Device> const&) + 728
20  IfosMobile Prod               0x00000001014407a4 -[AGSMapRenderer drawRequested] + 568
21  IfosMobile Prod               0x00000001014401b0 -[AGSMapRenderer pulse:] + 308
22  QuartzCore                    0x0000000188149904 CA::Display::DisplayLink::dispatch_items+ 47364 (unsigned long long, unsigned long long, unsigned long long) + 672
23  IOKit                         0x00000001844d81cc IODispatchCalloutFromCFMessage + 392
24  CoreFoundation                0x00000001841fc010 __CFMachPortPerform + 188
25  CoreFoundation                0x000000018421696c __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 56
26  CoreFoundation                0x0000000184216070 __CFRunLoopDoSource1 + 440
27  CoreFoundation                0x0000000184213b44 __CFRunLoopRun + 2196
28  CoreFoundation                0x0000000184133fb8 CFRunLoopRunSpecific + 436
29  GraphicsServices              0x0000000185fcbf84 GSEventRunModal + 100
30  UIKit                         0x000000018d7082f4 UIApplicationMain + 208
31  IfosMobile Prod               0x0000000101275f70 main + 4251504 (main.m:23)
32  libdyld.dylib                 0x0000000183c5656c start + 4
Thread 1 name:  com.apple.uikit.eventfetch-thread
Thread 1:
0   libsystem_kernel.dylib        0x0000000183d64bc4 mach_msg_trap + 8
1   libsystem_kernel.dylib        0x0000000183d64a3c mach_msg + 72
2   CoreFoundation                0x0000000184215c74 __CFRunLoopServiceMachPort + 196
3   CoreFoundation                0x0000000184213840 __CFRunLoopRun + 1424
4   CoreFoundation                0x0000000184133fb8 CFRunLoopRunSpecific + 436
5   Foundation                    0x0000000184b5d6e4 -[NSRunLoop+ 50916 (NSRunLoop) runMode:beforeDate:] + 304
6   Foundation                    0x0000000184b7cafc -[NSRunLoop+ 178940 (NSRunLoop) runUntilDate:] + 96
7   UIKit                         0x000000018e2672f4 -[UIEventFetcher threadMain] + 136
8   Foundation                    0x0000000184c5e860 __NSThread__start__ + 996
9   libsystem_pthread.dylib       0x0000000183e9831c _pthread_body + 308
10  libsystem_pthread.dylib       0x0000000183e981e8 _pthread_body + 0
11  libsystem_pthread.dylib       0x0000000183e96c28 thread_start + 4
Thread 2 name:  com.apple.NSURLConnectionLoader
Thread 2:
5   CFNetwork                     0x000000018489e264 +[NSURLConnection+ 717412 (Loader) _resourceLoadLoop:] + 404
6   Foundation                    0x0000000184c5e860 __NSThread__start__ + 996
7   libsystem_pthread.dylib       0x0000000183e9831c _pthread_body + 308
8   libsystem_pthread.dylib       0x0000000183e981e8 _pthread_body + 0
9   libsystem_pthread.dylib       0x0000000183e96c28 thread_start + 4
Thread 3 name:  Runtime Network Callback Thread
Thread 3:
0   CoreFoundation                0x0000000184144d6c CFStringGetBytes + 276
1   CoreFoundation                0x000000018415d3d8 CFStringCreateMutableCopy + 784
2   CoreFoundation                0x000000018415d3d8 CFStringCreateMutableCopy + 784
3   Foundation                    0x0000000184b7bde4 +[NSString stringWithString:] + 48
4   IfosMobile Prod               0x000000010155b530 +[AGSRequest ags_requestForURL:credential:resource:queryParameters:method:cachePolicy:timeoutInterval:userHeaders:allowsCellularAccess:] + 832
5   IfosMobile Prod               0x000000010155d3b0 -[AGSRequestOperation kickoffConnection] + 1264
6   Foundation                    0x0000000184c5ea50 __NSThreadPerformPerform + 340
7   CoreFoundation                0x00000001842162e8 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 24
8   CoreFoundation                0x0000000184216268 __CFRunLoopDoSource0 + 88
9   CoreFoundation                0x0000000184215af0 __CFRunLoopDoSources0 + 204
10  CoreFoundation                0x00000001842136c8 __CFRunLoopRun + 1048
11  CoreFoundation                0x0000000184133fb8 CFRunLoopRunSpecific + 436
12  Foundation                    0x0000000184b5d6e4 -[NSRunLoop+ 50916 (NSRunLoop) runMode:beforeDate:] + 304
13  IfosMobile Prod               0x0000000101643cfc -[AGSThreadTargetImpl mainRoutine] + 292
14  Foundation                    0x0000000184c5e860 __NSThread__start__ + 996
15  libsystem_pthread.dylib       0x0000000183e9831c _pthread_body + 308
16  libsystem_pthread.dylib       0x0000000183e981e8 _pthread_body + 0
17  libsystem_pthread.dylib       0x0000000183e96c28 thread_start + 4
Nicholas-Furness
Looks like the crash happened in Thread 10. Can you provide the stack for that thread please?
gautamsingh
 Incident Identifier: 4BA67324-CA44-44B7-BF98-A26B0FB9081E
CrashReporter Key:   9be293488c53df2b7f4b85507f50f123f4710896
Hardware Model:      iPad5,4
Process:             IfosMobile Prod [1510]
Code Type:           ARM-64 (Native)
Role:                Foreground
Parent Process:      launchd [1]
Date/Time:           2017-12-07 13:40:40.6776 +0800
Launch Time:         2017-12-07 13:36:37.1923 +0800
OS Version:          iPhone OS 11.1 (15B93)
Baseband Version:    6.17.00
Report Version:      104
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Subtype: KERN_INVALID_ADDRESS at 0x000000044927beb8
VM Region Info: 0x44927beb8 is not in any region.  Bytes after previous region: 10354147001
      REGION TYPE                      START - END             [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      MALLOC_NANO (reserved) 00000001d8000000-00000001e0000000 [128.0M] rw-/rwx SM=NUL  ...(unallocated)
      UNUSED SPACE AT END
Filtered syslog:
None found
Thread 0:
Thread 1:
Thread 2:
Thread 3:
Thread 4:
0   libsystem_pthread.dylib       0x0000000183e96c1c start_wqthread + 0
Thread 5:
Thread 6 name:  Dispatch queue: com.apple.root.default-qos
Thread 6:
0   IfosMobile Prod               0x0000000101705614 sk_memset32_portable+ 9033236 (unsigned int*, unsigned int, int) + 24
1   IfosMobile Prod               0x0000000101a3ffb4 Esri_runtimecore::Map_renderer::Canvas_drawable::draw_layer_with_simplified_load_+ 12418996 (std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Canvas_renderer::Draw_request> const&) + 344
2   IfosMobile Prod               0x0000000101a41c3c std::__1::__function::__func<Esri_runtimecore::Map_renderer::Canvas_drawable::add_draw_task_(std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Canvas_renderer::Draw_request> const&)::$_2, std::__1::allocator<Esri_runtimecore::Map_renderer::Canvas_drawable::add_draw_task_(std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Canvas_renderer::Draw_request> const&)::$_2>, void ()>::operator()+ 12426300 () + 168
3   IfosMobile Prod               0x0000000101de8cd8 std::__1::__function::__func<pplx::details::_MakeVoidToUnitFunc(std::__1::function<void ()> const&)::'lambda'(), std::__1::allocator<pplx::details::_MakeVoidToUnitFunc(std::__1::function<void ()> const&)::'lambda'()>, unsigned char ()>::operator()+ 16256216 () + 28
4   IfosMobile Prod               0x0000000101a417c0 pplx::details::_PPLTaskHandle<unsigned char, pplx::task<unsigned char>::_InitialTaskHandle<void, Esri_runtimecore::Map_renderer::Canvas_drawable::add_draw_task_(std::__1::shared_ptr<Esri_runtimecore::Map_renderer::Canvas_renderer::Draw_request> const&)::$_2, pplx::details::_TypeSelectorNoAsync>, pplx::details::_TaskProcHandle>::invoke+ 12425152 () const + 372
5   IfosMobile Prod               0x0000000101de8fe4 pplx::details::_TaskProcHandle::_RunChoreBridge+ 16256996 (void*) + 28
6   libdispatch.dylib             0x0000000183bf1048 _dispatch_client_callout + 16
7   libdispatch.dylib             0x0000000183bf8090 _dispatch_queue_override_invoke$VARIANT$mp + 716
8   libdispatch.dylib             0x0000000183bfe1c8 _dispatch_root_queue_drain + 596
9   libdispatch.dylib             0x0000000183bfdf10 _dispatch_worker_thread3 + 120
10  libsystem_pthread.dylib       0x0000000183e97120 _pthread_wqthread + 1268
11  libsystem_pthread.dylib       0x0000000183e96c20 start_wqthread + 4
Thread 7:
0   libsystem_kernel.dylib        0x0000000183d85dbc __workq_kernreturn + 8
1   libsystem_pthread.dylib       0x0000000183e96fa0 _pthread_wqthread + 884
2   libsystem_pthread.dylib       0x0000000183e96c20 start_wqthread + 4
Thread 8:
Thread 9 name:  Dispatch queue: com.apple.NSURLSession-work
Thread 9:
0   CoreFoundation                0x000000018412e07c _CFRetain + 24
1   CFNetwork                     0x00000001849cf88c HTTPHeaderDict::setValue+ 1968268 (HTTPHeaderKeyMixedValue const&, HTTPHeaderValueMixedValue const&) + 88
2   CFNetwork                     0x00000001849cf88c HTTPHeaderDict::setValue+ 1968268 (HTTPHeaderKeyMixedValue const&, HTTPHeaderValueMixedValue const&) + 88
3   CFNetwork                     0x00000001848b559c HTTPMessage::setHeaderFieldStringValue+ 812444 (CFNetworkConstantString::HTTPHeader::DomainString, __CFString const*) + 144
4   CFNetwork                     0x00000001848fe6b0 addHeaderIfMissing+ 1111728 (_CFURLRequest*, CFNetworkConstantString::HTTPHeader::DomainString, __CFString const*) + 224
5   CFNetwork                     0x00000001848fe404 HTTPProtocol::_createMutableCanonicalRequest+ 1111044 (__CFAllocator const*, _CFURLRequest const*, NSURLSession const*, void const*) + 336
6   CFNetwork                     0x00000001848fdeb0 HTTPProtocol::_createCanonicalRequest+ 1109680 (__CFAllocator const*, _CFURLRequest const*, NSURLSession const*, void const*) + 72
7   CFNetwork                     0x0000000184889f88 +[_NSCFURLProtocol canonicalRequestForRequest:task:] + 108
8   CFNetwork                     0x00000001847fb9b0 -[__NSURLSessionLocal _createCanonicalRequestForTask:] + 120
9   CFNetwork                     0x00000001847f87fc -[__NSURLSessionLocal _onqueue_canonicalizeTaskAndCreateConnection:] + 64
10  CFNetwork                     0x000000018481187c -[__NSCFLocalSessionTask _onqueue_completeInitialization] + 72
11  CFNetwork                     0x0000000184a35db0 __30-[__NSCFURLSessionTask resume]_block_invoke + 40
12  libdispatch.dylib             0x0000000183bf1088 _dispatch_call_block_and_release + 24
13  libdispatch.dylib             0x0000000183bf1048 _dispatch_client_callout + 16
14  libdispatch.dylib             0x0000000183bfae48 _dispatch_queue_serial_drain$VARIANT$mp + 528
15  libdispatch.dylib             0x0000000183bfb7d8 _dispatch_queue_invoke$VARIANT$mp + 340
16  libdispatch.dylib             0x0000000183bfc200 _dispatch_root_queue_drain_deferred_wlh$VARIANT$mp + 400
17  libdispatch.dylib             0x0000000183c044a0 _dispatch_workloop_worker_thread$VARIANT$mp + 644
18  libsystem_pthread.dylib       0x0000000183e96fd0 _pthread_wqthread + 932
19  libsystem_pthread.dylib       0x0000000183e96c20 start_wqthread + 4
Thread 10 name:  Dispatch queue: NSOperationQueue 0x1c443b540 (QOS: UNSPECIFIED)
Thread 10 Crashed:
0   libobjc.A.dylib               0x00000001834d0430 objc_msgSend + 16
1   Foundation                    0x0000000184b627f0 -[NSValue isEqual:] + 40
2   Foundation                    0x0000000184b57fcc probeGC + 456
3   Foundation                    0x0000000184b57dc4 -[NSConcreteMapTable objectForKey:] + 52
4   IfosMobile Prod               0x00000001014fc29c -[AGSNSURLSessionDemultiplexer URLSession:task:didCompleteWithError:] + 152
5   CFNetwork                     0x00000001849a5750 __51-[NSURLSession delegate_task:didCompleteWithError:]_block_invoke.207 + 76
6   Foundation                    0x0000000184c39310 __NSBLOCKOPERATION_IS_CALLING_OUT_TO_A_BLOCK__ + 16
7   Foundation                    0x0000000184b799e4 -[NSBlockOperation main] + 72
8   Foundation                    0x0000000184b69620 -[__NSOperationInternal _start:] + 848
9   libdispatch.dylib             0x0000000183bf1048 _dispatch_client_callout + 16
10  libdispatch.dylib             0x0000000183bf86c8 _dispatch_block_invoke_direct$VARIANT$mp + 288
11  libdispatch.dylib             0x0000000183bf1048 _dispatch_client_callout + 16
12  libdispatch.dylib             0x0000000183bf86c8 _dispatch_block_invoke_direct$VARIANT$mp + 288
13  libdispatch.dylib             0x0000000183bf8574 dispatch_block_perform$VARIANT$mp + 104
14  Foundation                    0x0000000184c3afe8 __NSOQSchedule_f + 376
15  libdispatch.dylib             0x0000000183bf1048 _dispatch_client_callout + 16
16  libdispatch.dylib             0x0000000183bf93d4 _dispatch_continuation_pop$VARIANT$mp + 428
17  libdispatch.dylib             0x0000000183bf7cd4 _dispatch_async_redirect_invoke$VARIANT$mp + 604
18  libdispatch.dylib             0x0000000183bfe1c8 _dispatch_root_queue_drain + 596
19  libdispatch.dylib             0x0000000183bfdf10 _dispatch_worker_thread3 + 120
20  libsystem_pthread.dylib       0x0000000183e97120 _pthread_wqthread + 1268
21  libsystem_pthread.dylib       0x0000000183e96c20 start_wqthread + 4
Thread 11 name:  Dispatch queue: com.apple.root.default-qos
Thread 11:
Thread 12:
Thread 10 crashed with ARM Thread State (64-bit):
    x0: 0x00000001c803d040   x1: 0x000000018e42a764   x2: 0x00000001c803d040   x3: 0x0000000000000000
    x4: 0x0000000000000000   x5: 0x0000000000000000   x6: 0x000000012dd3fb80   x7: 0x0000000000000810
    x8: 0x00000001b329f000   x9: 0x000000018e42c074  x10: 0x000000012e826e00  x11: 0x0000001f0000003f
   x12: 0x000000012e827140  x13: 0xbaddd8944927bead  x14: 0x00030c0000030c00  x15: 0x0000000000000000
   x16: 0x000000044927bea8  x17: 0x0000000184b627c8  x18: 0x0000000000000000  x19: 0x00000001c803d040
   x20: 0x00000001c0623be0  x21: 0x00000001c0623be0  x22: 0x0000000131521580  x23: 0x0000000000000001
   x24: 0x00000001b32aa000  x25: 0x0000000000000001  x26: 0x00000001c803d040  x27: 0x00000001b32aa000
   x28: 0x00000001b32aa000   fp: 0x000000016f50a8f0   lr: 0x0000000184b627f0
    sp: 0x000000016f50a8e0   pc: 0x00000001834d0430 cpsr: 0x20000000
Binary Images:
0x100e68000 - 0x102377fff IfosMobile Prod arm64  <13ba4b2a487438f78e5fdd0200b1d9e6> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/IfosMobile Prod
0x1027d8000 - 0x1027dffff Reachability arm64  <f447b84a23533d1b9ba1bd73334d03da> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/Reachability.framework/Reachability
0x1027f0000 - 0x102823fff AFNetworking arm64  <96f8e4769c843a86b4f310f81db5fb73> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/AFNetworking.framework/AFNetworking
0x102878000 - 0x102883fff FCUUID arm64  <555351060e873b9698eb6638ecf27657> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/FCUUID.framework/FCUUID
0x1028a4000 - 0x1028b3fff MBProgressHUD arm64  <c9fe89946ef439b4b4738bf363499b8f> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/MBProgressHUD.framework/MBProgressHUD
0x1028d4000 - 0x102913fff dyld arm64  <92368d6f78863cc88239f2e3ec79bba8> /usr/lib/dyld
0x102970000 - 0x102983fff SWRevealViewController arm64  <d8eed8f4238e3e30899dec92fce05f01> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/SWRevealViewController.framework/SWRevealViewController
0x1029a0000 - 0x1029abfff UIBarButtonItem_Badge arm64  <f1c8e5ea18963c0bbd849a44f18d3ba7> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/UIBarButtonItem_Badge.framework/UIBarButtonItem_Badge
0x1029bc000 - 0x1029cbfff UICKeyChainStore arm64  <49da5dfd28b236b0ad5ba2cc21c10217> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/UICKeyChainStore.framework/UICKeyChainStore
0x1029e0000 - 0x1029e7fff UIDevice_HardwareName arm64  <4079d59442483f73a0cb1b7344f05b9b> /var/containers/Bundle/Application/6ACB3DBC-C525-4F5B-BE63-BDDD0AA68A8F/IfosMobile Prod.app/Frameworks/UIDevice_HardwareName.framework/UIDevice_HardwareName
0x183435000 - 0x183436fff libSystem.B.dylib arm64  <758163f7d63f393a9c53e184688479d4> /usr/lib/libSystem.B.dylib
0x183437000 - 0x183490fff libc++.1.dylib arm64  <2c929c029baf3d0f84a2e636550af33c> /usr/lib/libc++.1.dylib
0x183491000 - 0x1834b1fff libc++abi.dylib arm64  <4e4a4bcb0b63363db460a93569a74fd6> /usr/lib/libc++abi.dylib
0x1834b4000 - 0x183b6ffff libobjc.A.dylib arm64  <5f420cdc6f593721a9cf0464bd87e1a2> /usr/lib/libobjc.A.dylib
0x183b70000 - 0x183b74fff libcache.dylib arm64  <899cd22e8e8b33cab299fb46175d7a5c> /usr/lib/system/libcache.dylib
0x183b75000 - 0x183b80fff libcommonCrypto.dylib arm64  <ed799302ae4534aa92dd727859a4e157> /usr/lib/system/libcommonCrypto.dylib
0x183b81000 - 0x183b84fff libcompiler_rt.dylib arm64  <ef90354df4533ea7aba7c780c7ffc720> /usr/lib/system/libcompiler_rt.dylib
0x183b85000 - 0x183b8cfff libcopyfile.dylib arm64  <2964b6d9e7303d5fb6e2b2dd0a29c508> /usr/lib/system/libcopyfile.dylib
0x183b8d000 - 0x183beffff libcorecrypto.dylib arm64  <1e6818828cfb3b5b940ed390607b27ac> /usr/lib/system/libcorecrypto.dylib
0x183bf0000 - 0x183c54fff libdispatch.dylib arm64  <a879dad0ed5c3e0bbfd5a8c14045bfb3> /usr/lib/system/libdispatch.dylib
0x183c55000 - 0x183c6ffff libdyld.dylib arm64  <30eea71a4f5b39ee8c6b426835348e81> /usr/lib/system/libdyld.dylib
0x183c70000 - 0x183c70fff liblaunch.dylib arm64  <27dbe9e050e3340dbad0477ae2e4aad5> /usr/lib/system/liblaunch.dylib
0x183c71000 - 0x183c76fff libmacho.dylib arm64  <850419a813223cd1bb9503ce69260633> /usr/lib/system/libmacho.dylib
0x183c77000 - 0x183c78fff libremovefile.dylib arm64  <d3c2e06992b63a7f82c3fa9bc3063bf8> /usr/lib/system/libremovefile.dylib
0x183c79000 - 0x183c90fff libsystem_asl.dylib arm64  <de4b81b9b41831caaabf2e72c4dcaf4c> /usr/lib/system/libsystem_asl.dylib
0x183c91000 - 0x183c91fff libsystem_blocks.dylib arm64  <efb6db5961f833839d1b172b1115d036> /usr/lib/system/libsystem_blocks.dylib
0x183c92000 - 0x183d0ffff libsystem_c.dylib arm64  <7fb972b447d53c13a4dbd0627694986e> /usr/lib/system/libsystem_c.dylib
0x183d10000 - 0x183d14fff libsystem_configuration.dylib arm64  <11c279f77d6839a2a69cdc6a0c23e199> /usr/lib/system/libsystem_configuration.dylib
0x183d15000 - 0x183d1afff libsystem_containermanager.dylib arm64  <37c489754693384a8ea2a31371a7aece> /usr/lib/system/libsystem_containermanager.dylib
0x183d1b000 - 0x183d1cfff libsystem_coreservices.dylib arm64  <9f860b60c02d350db09fbe9d01559302> /usr/lib/system/libsystem_coreservices.dylib
0x183d1d000 - 0x183d1efff libsystem_darwin.dylib arm64  <4008b3d5eb873870a8c7c74b98c4f932> /usr/lib/system/libsystem_darwin.dylib
0x183d1f000 - 0x183d25fff libsystem_dnssd.dylib arm64  <d76be8b55c44312a9a73659a4ab73083> /usr/lib/system/libsystem_dnssd.dylib
0x183d26000 - 0x183d63fff libsystem_info.dylib arm64  <279ecedac89e33a5bcb6ad1ba5d00d56> /usr/lib/system/libsystem_info.dylib
0x183d64000 - 0x183d8bfff libsystem_kernel.dylib arm64  <2d85f169eee736c48145938bdef80a7e> /usr/lib/system/libsystem_kernel.dylib
0x183d8c000 - 0x183db9fff libsystem_m.dylib arm64  <69def43d33203f63bfe5b18c8e66ab7d> /usr/lib/system/libsystem_m.dylib
0x183dba000 - 0x183dd4fff libsystem_malloc.dylib arm64  <5dc06c81789a35669e206dfba7f5bd61> /usr/lib/system/libsystem_malloc.dylib
0x183dd5000 - 0x183e74fff libsystem_network.dylib arm64  <fb033ce57bc0375fa47e806b9b2ecbdd> /usr/lib/system/libsystem_network.dylib
0x183e75000 - 0x183e80fff libsystem_networkextension.dylib arm64  <4964fbe5c0a435cc8274d0744fd1997b> /usr/lib/system/libsystem_networkextension.dylib
0x183e81000 - 0x183e8bfff libsystem_notify.dylib arm64  <1130597d24e436c7ad24d3441ec85a5b> /usr/lib/system/libsystem_notify.dylib
0x183e8c000 - 0x183e95fff libsystem_platform.dylib arm64  <84cb39fe4d5c3ad09dc3d346f3870147> /usr/lib/system/libsystem_platform.dylib
0x183e96000 - 0x183ea5fff libsystem_pthread.dylib arm64  <80157cb282873e53afb000d8fc29211c> /usr/lib/system/libsystem_pthread.dylib
0x183ea6000 - 0x183ea9fff libsystem_sandbox.dylib arm64  <dc0a703516a034a398eaf57e0a4fcede> /usr/lib/system/libsystem_sandbox.dylib
0x183eaa000 - 0x183eb1fff libsystem_symptoms.dylib arm64  <3fd153a10e77340893e5245dda8d7b81> /usr/lib/system/libsystem_symptoms.dylib
0x183eb2000 - 0x183ec5fff libsystem_trace.dylib arm64  <31b77eb264253ddc85d9f91ffe42fb60> /usr/lib/system/libsystem_trace.dylib
0x183ec6000 - 0x183ecbfff libunwind.dylib arm64  <59aed54b354e3b7c9becdd5ef836ab38> /usr/lib/system/libunwind.dylib
0x183ecc000 - 0x183eccfff libvminterpose.dylib arm64  <c48901de942d3ec4be1c11cbfa62f6b4> /usr/lib/system/libvminterpose.dylib
0x183ecd000 - 0x183ef7fff libxpc.dylib arm64  <7a357823916e3d4eb3ab70c81df13fe9> /usr/lib/system/libxpc.dylib
0x183ef8000 - 0x184119fff libicucore.A.dylib arm64  <0f2de9d3a1483204a31b4dd8929c49c4> /usr/lib/libicucore.A.dylib
0x18411a000 - 0x18412bfff libz.1.dylib arm64  <8a7d4704f23638328cb15c26018052c3> /usr/lib/libz.1.dylib
0x18412c000 - 0x1844bffff CoreFoundation arm64  <a595c2ee553e3a1fa6959947247b034e> /System/Library/Frameworks/CoreFoundation.framework/CoreFoundation
0x1844c0000 - 0x1844d0fff libbsm.0.dylib arm64  <6185b9ae6b813622bfeaa01ead4ccccc> /usr/lib/libbsm.0.dylib
0x1844d1000 - 0x1844d1fff libenergytrace.dylib arm64  <19602b20751b315eb1a0fb8d9546ab39> /usr/lib/libenergytrace.dylib
0x1844d2000 - 0x184557fff IOKit arm64  <56c80784bb7d336cba48fc24fd8db4ad> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x184558000 - 0x184641fff libxml2.2.dylib arm64  <864c06ea4b37398eb1db31ef4afd37ec> /usr/lib/libxml2.2.dylib
0x184642000 - 0x18464ffff libbz2.1.0.dylib arm64  <68e3ae20023333e49736f875cba60f3f> /usr/lib/libbz2.1.0.dylib
0x184650000 - 0x184668fff liblzma.5.dylib arm64  <f1c34a4c33b2317c80a19c51af7a2790> /usr/lib/liblzma.5.dylib
0x184669000 - 0x1847c7fff libsqlite3.dylib arm64  <62bf3772156d3ded9bcddf16302e39fe> /usr/lib/libsqlite3.dylib
0x1847c8000 - 0x1847eefff libMobileGestalt.dylib arm64  <4d020821132037469c2ddbe4037bb184> /usr/lib/libMobileGestalt.dylib
0x1847ef000 - 0x184b50fff CFNetwork arm64  <8d01fc28db473e1ca098245bb236b220> /System/Library/Frameworks/CFNetwork.framework/CFNetwork
0x184b51000 - 0x184e4afff Foundation arm64  <531f6c3218e63e6e8c672e6975df5429> /System/Library/Frameworks/Foundation.framework/Foundation
0x184e4b000 - 0x184f37fff Security arm64  <04b8415d6e3f3c149fe9c1831637964f> /System/Library/Frameworks/Security.framework/Security
0x184f38000 - 0x184fa4fff SystemConfiguration arm64  <ccf7720aa99f3825a81b0a4ecd0bab85> /System/Library/Frameworks/SystemConfiguration.framework/SystemConfiguration
0x184fa5000 - 0x184fdbfff libCRFSuite.dylib arm64  <a416be07fd5c3d2eb833094e7576569a> /usr/lib/libCRFSuite.dylib
0x184fdc000 - 0x184fdcfff libapple_crypto.dylib arm64  <0e808860405237c2901a7938edeea22b> /usr/lib/libapple_crypto.dylib
0x184fdd000 - 0x184ff3fff libapple_nghttp2.dylib arm64  <8fa0c8f9b54234a3b87ae298ca5139dc> /usr/lib/libapple_nghttp2.dylib
0x184ff4000 - 0x18501dfff libarchive.2.dylib arm64  <aff604ea98913fa4a7d2cab80cb4fc45> /usr/lib/libarchive.2.dylib
0x18501e000 - 0x1850cbfff libboringssl.dylib arm64  <966db132b26c3afcb460425ef0db04b6> /usr/lib/libboringssl.dylib
0x1850cc000 - 0x1850e3fff libcoretls.dylib arm64  <3e6ce87382a93664978aa6ea5b20e074> /usr/lib/libcoretls.dylib
0x1850e4000 - 0x1850e5fff libcoretls_cfhelpers.dylib arm64  <d41424fe3e8031b0ade319cf8057c4b8> /usr/lib/libcoretls_cfhelpers.dylib
0x1850e6000 - 0x1850e7fff liblangid.dylib arm64  <455f60ef54b03b0d8e9de9c21b90f059> /usr/lib/liblangid.dylib
0x1850e8000 - 0x1851b9fff libnetwork.dylib arm64  <94343169019c3b98a34bd169dd4ab849> /usr/lib/libnetwork.dylib
0x1851ba000 - 0x1851ecfff libpcap.A.dylib arm64  <41f1788a0bd13dc08bc3e41b7cec1804> /usr/lib/libpcap.A.dylib
0x1851ed000 - 0x185222fff libusrtcp.dylib arm64  <c518b32fcbc93bbeadeb31b791bd7075> /usr/lib/libusrtcp.dylib
0x185223000 - 0x18522cfff IOSurface arm64  <ab424af7e61e3a15877c765a031a6a66> /System/Library/Frameworks/IOSurface.framework/IOSurface
0x18522d000 - 0x1852d2fff libBLAS.dylib arm64  <27adc89bb9af3e8d9b9f36eaaf4e62b7> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libBLAS.dylib
0x1852d3000 - 0x185602fff libLAPACK.dylib arm64  <df6267a11c3d322e831c53e8abd5d903> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libLAPACK.dylib
0x185603000 - 0x18586ffff vImage arm64  <28dca740a82b3526a35bd6ae5eb3e840> /System/Library/Frameworks/Accelerate.framework/Frameworks/vImage.framework/vImage
0x185870000 - 0x185881fff libSparseBLAS.dylib arm64  <11628ec1764d3e048b8358b4dd13831f> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libSparseBLAS.dylib
0x185882000 - 0x1858a6fff libvMisc.dylib arm64  <49d9e5029b4b3e2f9b51cd87f0ea0ee1> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libvMisc.dylib
0x1858a7000 - 0x1858d2fff libBNNS.dylib arm64  <d8cf62358440302985ddc3d42e7ee0ec> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libBNNS.dylib
0x1858d3000 - 0x1858e8fff libLinearAlgebra.dylib arm64  <26de94ae6a723e1cbb9cfe07c71fec5b> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libLinearAlgebra.dylib
0x1858e9000 - 0x1858edfff libQuadrature.dylib arm64  <dae4943a47b7343aac1455f391adde55> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libQuadrature.dylib
0x1858ee000 - 0x185944fff libSparse.dylib arm64  <5a6c6e0391c43f10bf3bb2e02ebc4cb0> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libSparse.dylib
0x185945000 - 0x1859bdfff libvDSP.dylib arm64  <724fdaba1e8c3d89aec4582bb19406ec> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/libvDSP.dylib
0x1859be000 - 0x1859befff vecLib arm64  <8142ed76691b32a0819414d62bd76fb7> /System/Library/Frameworks/Accelerate.framework/Frameworks/vecLib.framework/vecLib
0x1859bf000 - 0x1859bffff Accelerate arm64  <2db9a65ffd55358185d0df079baf981b> /System/Library/Frameworks/Accelerate.framework/Accelerate
0x1859c0000 - 0x1859d5fff libcompression.dylib arm64  <45f8251c28e03c5b904453e2c91c355d> /usr/lib/libcompression.dylib
0x1859d6000 - 0x185f19fff CoreGraphics arm64  <cfc326d010aa3606b61a8ee2fde1bfa3> /System/Library/Frameworks/CoreGraphics.framework/CoreGraphics
0x185f1a000 - 0x185f22fff IOAccelerator arm64  <7eee49bf7c6033bb8ac4cb174aeacb32> /System/Library/PrivateFrameworks/IOAccelerator.framework/IOAccelerator
0x185f23000 - 0x185f26fff libCoreFSCache.dylib arm64  <355b472a1eee3d63a3273bc4f789e64d> /System/Library/Frameworks/OpenGLES.framework/libCoreFSCache.dylib
0x185f27000 - 0x185fc0fff Metal arm64  <6a23f41afb11327ba8a6344b4ccc10a6> /System/Library/Frameworks/Metal.framework/Metal
0x185fc1000 - 0x185fd4fff GraphicsServices arm64  <58a9a51f40f439e8a33bbfbfaab3f679> /System/Library/PrivateFrameworks/GraphicsServices.framework/GraphicsServices
0x185fd5000 - 0x18612cfff MobileCoreServices arm64  <d82d7dec1905330687770e2b0817f7a4> /System/Library/Frameworks/MobileCoreServices.framework/MobileCoreServices
0x18612d000 - 0x18612ffff IOSurfaceAccelerator arm64  <1255d0b9a57530368145347b25a3c107> /System/Library/PrivateFrameworks/IOSurfaceAccelerator.framework/IOSurfaceAccelerator
0x186130000 - 0x186171fff AppleJPEG arm64  <26d5f3e5836231ada8e3a7f0f0e4e577> /System/Library/PrivateFrameworks/AppleJPEG.framework/AppleJPEG
0x186172000 - 0x18671ffff ImageIO arm64  <e161bfa3089834b0b586325eba45e7b5> /System/Library/Frameworks/ImageIO.framework/ImageIO
0x186720000 - 0x186784fff BaseBoard arm64  <f991ec75e241385cba85a5ccc8369240> /System/Library/PrivateFrameworks/BaseBoard.framework/BaseBoard
0x186785000 - 0x18679bfff AssertionServices arm64  <126054bc41653e79a7be42a4ce84fc25> /System/Library/PrivateFrameworks/AssertionServices.framework/AssertionServices
0x18679c000 - 0x1867a4fff CorePhoneNumbers arm64  <8ccb780bdc323fa9a985e4219fe0a0ab> /System/Library/PrivateFrameworks/CorePhoneNumbers.framework/CorePhoneNumbers
0x1867a5000 - 0x1867e9fff AppSupport arm64  <9e545bd14dc836c4bcdf933631e284f3> /System/Library/PrivateFrameworks/AppSupport.framework/AppSupport
0x1867ea000 - 0x186802fff CrashReporterSupport arm64  <12576a0d3a44313e9ab396b3df3fe317> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/CrashReporterSupport
0x186803000 - 0x186808fff AggregateDictionary arm64  <b94fb609d5863a8784be5cdc8bca2f90> /System/Library/PrivateFrameworks/AggregateDictionary.framework/AggregateDictionary
0x186809000 - 0x18688afff libTelephonyUtilDynamic.dylib arm64  <e39a53900ae035a390037f61f79dff47> /usr/lib/libTelephonyUtilDynamic.dylib
0x18688b000 - 0x1868aafff ProtocolBuffer arm64  <6a2021c7ddca3ee8851ed031aed3a1f0> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/ProtocolBuffer
0x1868ab000 - 0x1868d7fff MobileKeyBag arm64  <40ebc86ba6a43f9797a816709d790ed1> /System/Library/PrivateFrameworks/MobileKeyBag.framework/MobileKeyBag
0x1868d8000 - 0x18690cfff BackBoardServices arm64  <950bdfa62b2f3552a53b8e8eb8f232b9> /System/Library/PrivateFrameworks/BackBoardServices.framework/BackBoardServices
0x18690d000 - 0x186968fff FrontBoardServices arm64  <c231dcbbf36535c9a1ee97dac74ea426> /System/Library/PrivateFrameworks/FrontBoardServices.framework/FrontBoardServices
0x186969000 - 0x1869a5fff SpringBoardServices arm64  <148423be6fb63a799e7e6416d87658e6> /System/Library/PrivateFrameworks/SpringBoardServices.framework/SpringBoardServices
0x1869a6000 - 0x1869b4fff PowerLog arm64  <8d9f420d9b9a3bec8fd2848630feea55> /System/Library/PrivateFrameworks/PowerLog.framework/PowerLog
0x1869b5000 - 0x1869d0fff CommonUtilities arm64  <392eba533f5b31799808141aeb14e2f3> /System/Library/PrivateFrameworks/CommonUtilities.framework/CommonUtilities
0x1869d1000 - 0x1869dbfff liblockdown.dylib arm64  <19e3a05076ec3d6eaded8367a8e41179> /usr/lib/liblockdown.dylib
0x1869dc000 - 0x186cdbfff CoreData arm64  <ec41c90a0d393f1bbd4dd5d6e536d8a7> /System/Library/Frameworks/CoreData.framework/CoreData
0x186cdc000 - 0x186ce2fff TCC arm64  <b3b11664f1d13ca5b285654dfa210e43> /System/Library/PrivateFrameworks/TCC.framework/TCC
0x186ce3000 - 0x186ceafff libcupolicy.dylib arm64  <1859d2d80dfd3bafb7590dccef63c205> /usr/lib/libcupolicy.dylib
0x186ceb000 - 0x186d77fff CoreTelephony arm64  <bb31d2e639ba3c3a8bfda1d738d5a745> /System/Library/Frameworks/CoreTelephony.framework/CoreTelephony
0x186d78000 - 0x186dcefff Accounts arm64  <4067ebac613932719a6d6c057dc0069d> /System/Library/Frameworks/Accounts.framework/Accounts
0x186dcf000 - 0x186df8fff AppleSauce arm64  <2f45aa0efae53d4aa4ed3fc2d8733c6c> /System/Library/PrivateFrameworks/AppleSauce.framework/AppleSauce
0x186df9000 - 0x186e01fff DataMigration arm64  <805163cb2c9d3e12820f4e79acc1aa08> /System/Library/PrivateFrameworks/DataMigration.framework/DataMigration
0x186e02000 - 0x186e08fff Netrb arm64  <b4fda2e9d3253798818a82de980436e4> /System/Library/PrivateFrameworks/Netrb.framework/Netrb
0x186e09000 - 0x186e3cfff PersistentConnection arm64  <09708169f81233eb87947fc1deca1b03> /System/Library/PrivateFrameworks/PersistentConnection.framework/PersistentConnection
0x186e3d000 - 0x186e4efff libmis.dylib arm64  <0c6e60f5e4ea3b64b49a3216371fa42e> /usr/lib/libmis.dylib
0x186e4f000 - 0x186f4ffff ManagedConfiguration arm64  <9c8504424e2937bbb4900f60079e3b69> /System/Library/PrivateFrameworks/ManagedConfiguration.framework/ManagedConfiguration
0x186f50000 - 0x186f55fff libReverseProxyDevice.dylib arm64  <6ef20e9effb13e96ad8ed1f388ee088a> /usr/lib/libReverseProxyDevice.dylib
0x186f56000 - 0x186f67fff libamsupport.dylib arm64  <c5fa3cf62bc036b2b68e233800aceb52> /usr/lib/libamsupport.dylib
0x186f68000 - 0x186f6dfff libCoreVMClient.dylib arm64  <bc0673d20ba8317faeb8959e853cdbba> /System/Library/Frameworks/OpenGLES.framework/libCoreVMClient.dylib
0x186f6e000 - 0x186f6ffff libCVMSPluginSupport.dylib arm64  <121c6cdac48d3108a80b1edb3594dc65> /System/Library/Frameworks/OpenGLES.framework/libCVMSPluginSupport.dylib
0x186f70000 - 0x186f73fff libutil.dylib arm64  <b22dc249400e3e36b935170dcfb29284> /usr/lib/libutil.dylib
0x186f74000 - 0x186fb5fff libGLImage.dylib arm64  <1db5ddb7c6723e2e93c02a83da0d1e2f> /System/Library/Frameworks/OpenGLES.framework/libGLImage.dylib
0x186fb6000 - 0x187023fff APFS arm64  <10d9607a11023a018323a1c9e338b42c> /System/Library/PrivateFrameworks/APFS.framework/APFS
0x187024000 - 0x187055fff MediaKit arm64  <7ae894076b623ce993c0cdc663d2b8a4> /System/Library/PrivateFrameworks/MediaKit.framework/MediaKit
0x187056000 - 0x18706efff libSERestoreInfo.dylib arm64  <b6ecf2ef64093d37a93bde6898fc0a6f> /usr/lib/updaters/libSERestoreInfo.dylib
0x187073000 - 0x1870affff DiskImages arm64  <23d7d2c9ddef3878af9ca98b2c247dce> /System/Library/PrivateFrameworks/DiskImages.framework/DiskImages
0x1870b0000 - 0x1870bafff libGFXShared.dylib arm64  <557214c8e07a37b38dca7955cdfc93fa> /System/Library/Frameworks/OpenGLES.framework/libGFXShared.dylib
0x1870bb000 - 0x187100fff libauthinstall.dylib arm64  <2001f1428c0934d5bd6d6e71a38c583c> /usr/lib/libauthinstall.dylib
0x187101000 - 0x187109fff IOMobileFramebuffer arm64  <143ff2624f87332aab633ff78dfdf160> /System/Library/PrivateFrameworks/IOMobileFramebuffer.framework/IOMobileFramebuffer
0x18710a000 - 0x187115fff OpenGLES arm64  <918bf7e88aca33aaa82db91c18994512> /System/Library/Frameworks/OpenGLES.framework/OpenGLES
0x187116000 - 0x18719dfff ColorSync arm64  <9d4b8ae2141e30d49fde3b34fb6a1c9d> /System/Library/PrivateFrameworks/ColorSync.framework/ColorSync
0x18719e000 - 0x1871c8fff CoreVideo arm64  <eaa1d002a6d63589976ffb475b29c225> /System/Library/Frameworks/CoreVideo.framework/CoreVideo
0x1871c9000 - 0x1871cafff libCTGreenTeaLogger.dylib arm64  <be096b2f2d8d3ddabe4364ad89c44232> /usr/lib/libCTGreenTeaLogger.dylib
0x1871cb000 - 0x18732cfff CoreAudio arm64  <a030dfac788139318304b30c0900bd30> /System/Library/Frameworks/CoreAudio.framework/CoreAudio
0x18732d000 - 0x18735bfff CoreAnalytics arm64  <1166b65708fb34018c76da00cc3776ed> /System/Library/PrivateFrameworks/CoreAnalytics.framework/CoreAnalytics
0x18735c000 - 0x18735ffff UserFS arm64  <3746d77c7ccd352eb4921fb928d51531> /System/Library/PrivateFrameworks/UserFS.framework/UserFS
0x187360000 - 0x1874c8fff CoreMedia arm64  <1267315307de3ce1804ed7beb2b36213> /System/Library/Frameworks/CoreMedia.framework/CoreMedia
0x1874c9000 - 0x1874dbfff libprotobuf-lite.dylib arm64  <266a884c40d934e9a426a600b2f4f40b> /usr/lib/libprotobuf-lite.dylib
0x1874dc000 - 0x187540fff libprotobuf.dylib arm64  <85b7ff55790b35a08a1dbc52eb299b75> /usr/lib/libprotobuf.dylib
0x187541000 - 0x187809fff libAWDSupportFramework.dylib arm64  <6ad8de9a862d30d4b08bb278ab9b58d9> /usr/lib/libAWDSupportFramework.dylib
0x18780a000 - 0x187850fff WirelessDiagnostics arm64  <d9875ae5cf7931eb9fe7e8b3e4b02b40> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/WirelessDiagnostics
0x187851000 - 0x187908fff VideoToolbox arm64  <61ac355e2f243ed59726a189af4821ca> /System/Library/Frameworks/VideoToolbox.framework/VideoToolbox
0x187909000 - 0x187a14fff libFontParser.dylib arm64  <137c2b72a8633508ab4f960d014e4918> /System/Library/PrivateFrameworks/FontServices.framework/libFontParser.dylib
0x187a15000 - 0x187a16fff FontServices arm64  <01da4c65d96c384f87512caa022e278a> /System/Library/PrivateFrameworks/FontServices.framework/FontServices
0x187a17000 - 0x187b65fff CoreText arm64  <3b1e7c3bd1663f42b23e4df4b855d0e1> /System/Library/Frameworks/CoreText.framework/CoreText
0x187b66000 - 0x187b75fff IntlPreferences arm64  <a1c202a320dc35a3a3fa55d91ad72b1b> /System/Library/PrivateFrameworks/IntlPreferences.framework/IntlPreferences
0x187b76000 - 0x187b7efff RTCReporting arm64  <e69c2b50cdfb332b8cf0ec2c4e0e39b0> /System/Library/PrivateFrameworks/RTCReporting.framework/RTCReporting
0x187b7f000 - 0x187beafff CoreBrightness arm64  <cab5638b8fb335a49485d57d41dd36f9> /System/Library/PrivateFrameworks/CoreBrightness.framework/CoreBrightness
0x187beb000 - 0x187bf5fff libAudioStatistics.dylib arm64  <0118273e27aa3f2aa41e867ccf061507> /usr/lib/libAudioStatistics.dylib
0x187bf6000 - 0x18813dfff AudioToolbox arm64  <6ccaa70c496f392991f6ff2c3772867e> /System/Library/Frameworks/AudioToolbox.framework/AudioToolbox
0x18813e000 - 0x188367fff QuartzCore arm64  <4d31b8ef0437344790ab32df354badfc> /System/Library/Frameworks/QuartzCore.framework/QuartzCore
0x188368000 - 0x188373fff MediaAccessibility arm64  <790859d5bd44340c9a23dfb7c3f3dee2> /System/Library/Frameworks/MediaAccessibility.framework/MediaAccessibility
0x188374000 - 0x188466fff libiconv.2.dylib arm64  <5c1a803af4f83283afa918bce80fea86> /usr/lib/libiconv.2.dylib
0x188467000 - 0x188483fff NetworkStatistics arm64  <525d25d10880389495d69b38fdb2a40e> /System/Library/PrivateFrameworks/NetworkStatistics.framework/NetworkStatistics
0x188484000 - 0x188499fff MPSCore arm64  <ea2d6092b849319a8a5e30241a916836> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSCore.framework/MPSCore
0x18849a000 - 0x1884fefff MPSImage arm64  <4b94f749163f3403b4dc56098ec3a7d6> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSImage.framework/MPSImage
0x1884ff000 - 0x18851bfff MPSMatrix arm64  <35ad36157bf1303f883abc8672de55fd> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSMatrix.framework/MPSMatrix
0x18851c000 - 0x18852afff CoreAUC arm64  <f825cd4460223fe592ace716d76f4729> /System/Library/PrivateFrameworks/CoreAUC.framework/CoreAUC
0x18852b000 - 0x188b94fff MediaToolbox arm64  <8cc9125b15323a4ba1b18000c39fca50> /System/Library/Frameworks/MediaToolbox.framework/MediaToolbox
0x188b95000 - 0x188c52fff MPSNeuralNetwork arm64  <8af204c9d77d35f9aa6c1ea2046543b1> /System/Library/Frameworks/MetalPerformanceShaders.framework/Frameworks/MPSNeuralNetwork.framework/MPSNeuralNetwork
0x188c53000 - 0x188c53fff MetalPerformanceShaders arm64  <c18ce0cdf988328db9bb97e6fa740ad5> /System/Library/Frameworks/MetalPerformanceShaders.framework/MetalPerformanceShaders
0x188c54000 - 0x189087fff FaceCore arm64  <1dbd061f7eea34a4b667036d78fcb0d6> /System/Library/PrivateFrameworks/FaceCore.framework/FaceCore
0x189088000 - 0x189095fff GraphVisualizer arm64  <4a49abe6dfc53d0eb02314bfc77a864e> /System/Library/PrivateFrameworks/GraphVisualizer.framework/GraphVisualizer
0x189096000 - 0x18923bfff libFosl_dynamic.dylib arm64  <8f75a8da4b1e3e27a00c6923d6b2b254> /usr/lib/libFosl_dynamic.dylib
0x18923c000 - 0x1894aefff CoreImage arm64  <be956a0e714133c5a82918ceb5f95e1d> /System/Library/Frameworks/CoreImage.framework/CoreImage
0x1894af000 - 0x18969bfff CoreMotion arm64  <28eeeeac0b4f3beb8b959ccfe71a7575> /System/Library/Frameworks/CoreMotion.framework/CoreMotion
0x18969c000 - 0x1896cafff CoreBluetooth arm64  <c4d53cc24cba39d285b7c9a9fdf5984e> /System/Library/Frameworks/CoreBluetooth.framework/CoreBluetooth
0x1896cb000 - 0x1896edfff PlugInKit arm64  <3ce66a7ae51738318f6d671190b68f23> /System/Library/PrivateFrameworks/PlugInKit.framework/PlugInKit
0x1896ee000 - 0x189914fff Celestial arm64  <ee25b3dcb4253e508e5584d1e71f0d81> /System/Library/PrivateFrameworks/Celestial.framework/Celestial
0x189915000 - 0x189997fff Quagga arm64  <43e676d34b8031ebb59c42c3223b9f45> /System/Library/PrivateFrameworks/Quagga.framework/Quagga
0x189998000 - 0x189a89fff AVFAudio arm64  <7583a1232e4d363fbfb3fad21d33622d> /System/Library/Frameworks/AVFoundation.framework/Frameworks/AVFAudio.framework/AVFAudio
0x189a8a000 - 0x189c72fff AVFoundation arm64  <a5818b9a86ae32e8a8bb3faafc7d110e> /System/Library/Frameworks/AVFoundation.framework/AVFoundation
0x189c73000 - 0x189c96fff CacheDelete arm64  <85bd8b5c28bd384a9a5e49572a617cfe> /System/Library/PrivateFrameworks/CacheDelete.framework/CacheDelete
0x189c97000 - 0x189cbcfff StreamingZip arm64  <8796a3836eb3354982d0d41d6d736480> /System/Library/PrivateFrameworks/StreamingZip.framework/StreamingZip
0x189cbd000 - 0x189ccefff CoreEmoji arm64  <4cecedf58e2d3be683013b50a6a02a7f> /System/Library/PrivateFrameworks/CoreEmoji.framework/CoreEmoji
0x189ccf000 - 0x189d1dfff CoreLocationProtobuf arm64  <748895402453357cb9701e4bc2a0591e> /System/Library/PrivateFrameworks/CoreLocationProtobuf.framework/CoreLocationProtobuf
0x189d1e000 - 0x189d25fff SymptomDiagnosticReporter arm64  <ef30b93b29ca3f409e3e5524e4f16967> /System/Library/PrivateFrameworks/SymptomDiagnosticReporter.framework/SymptomDiagnosticReporter
0x189d26000 - 0x18a61ffff GeoServices arm64  <a608efa8356a3a94be86c1724db0b5fd> /System/Library/PrivateFrameworks/GeoServices.framework/GeoServices
0x18a620000 - 0x18a636fff MobileAsset arm64  <99569f509d32350ab76452550e779813> /System/Library/PrivateFrameworks/MobileAsset.framework/MobileAsset
0x18a637000 - 0x18a678fff Lexicon arm64  <f1fce7c14ff73b6682d6ad9cb8342d30> /System/Library/PrivateFrameworks/Lexicon.framework/Lexicon
0x18a679000 - 0x18a689fff libcmph.dylib arm64  <2dfa6bc580033e86802b802077bb0e1a> /usr/lib/libcmph.dylib
0x18a68a000 - 0x18a7a6fff LanguageModeling arm64  <8777f95077b0357e8556993649055ef7> /System/Library/PrivateFrameworks/LanguageModeling.framework/LanguageModeling
0x18a7a7000 - 0x18a7befff libmarisa.dylib arm64  <7053c6b0fa823337b6552ee91721c193> /usr/lib/libmarisa.dylib
0x18a7bf000 - 0x18a859fff CoreLocation arm64  <5fb8d3a8b06e3c6d9cf1be40f37dd6bc> /System/Library/Frameworks/CoreLocation.framework/CoreLocation
0x18a85a000 - 0x18a85afff PhoneNumbers arm64  <13d66f5654c936068d36a92368c53501> /System/Library/PrivateFrameworks/PhoneNumbers.framework/PhoneNumbers
0x18a85b000 - 0x18a866fff libChineseTokenizer.dylib arm64  <1afcbc00ba3e333d9522a1604f98a508> /usr/lib/libChineseTokenizer.dylib
0x18a867000 - 0x18a914fff libmecab_em.dylib arm64  <b377039ba81333f887f0e1f33c4e26c1> /usr/lib/libmecab_em.dylib
0x18a915000 - 0x18a916fff libThaiTokenizer.dylib arm64  <66649e3b85063a8ab488d7052c1e05ba> /usr/lib/libThaiTokenizer.dylib
0x18a917000 - 0x18a91bfff libgermantok.dylib arm64  <e9de3a303f513af68365dc5d825df304> /usr/lib/libgermantok.dylib
0x18a91c000 - 0x18a973fff CoreNLP arm64  <a08dca2253c43d35be016deb417c654d> /System/Library/PrivateFrameworks/CoreNLP.framework/CoreNLP
0x18a974000 - 0x18ab31fff MobileSpotlightIndex arm64  <a50e41739d513d2f871553a5f4899b8b> /System/Library/PrivateFrameworks/MobileSpotlightIndex.framework/MobileSpotlightIndex
0x18ab32000 - 0x18ab8ffff CoreSpotlight arm64  <86c8a45ef21d356788df90b001e0f4ed> /System/Library/Frameworks/CoreSpotlight.framework/CoreSpotlight
0x18ab9c000 - 0x18b56dfff JavaScriptCore arm64  <d70c33a4cb983017b6e3f873a9cc526f> /System/Library/Frameworks/JavaScriptCore.framework/JavaScriptCore
0x18b56e000 - 0x18b573fff libheimdal-asn1.dylib arm64  <06adbbc5111a32018d1f6a06c2851217> /usr/lib/libheimdal-asn1.dylib
0x18b574000 - 0x18b5eefff libate.dylib arm64  <60ac7cf9f17c3ea0affbb578902c5835> /usr/lib/libate.dylib
0x18b5ef000 - 0x18b691fff TextureIO arm64  <3da4657eb59b3cccb3af48b53e35d3ce> /System/Library/PrivateFrameworks/TextureIO.framework/TextureIO
0x18b692000 - 0x18b75cfff CoreUI arm64  <a624e8645f21342ca8b29c37fb928873> /System/Library/PrivateFrameworks/CoreUI.framework/CoreUI
0x18b75d000 - 0x18b766fff MobileIcons arm64  <4e5d943756b739c1a6445ad37d85ad2c> /System/Library/PrivateFrameworks/MobileIcons.framework/MobileIcons
0x18b767000 - 0x18b775fff AppleFSCompression arm64  <da1538d03e2f37bb91e95d3a80d1cba3> /System/Library/PrivateFrameworks/AppleFSCompression.framework/AppleFSCompression
0x18b776000 - 0x18b7cefff TextInput arm64  <9f83a5941cb63ef887bc1e3efe279e6e> /System/Library/PrivateFrameworks/TextInput.framework/TextInput
0x18b7cf000 - 0x18b7f7fff libxslt.1.dylib arm64  <71af16d2aa4b3e9dbf4ee976f0eb79ab> /usr/lib/libxslt.1.dylib
0x18b7f8000 - 0x18b82dfff DataDetectorsCore arm64  <f8ababfe435b31739a9bcdff82b0e953> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/DataDetectorsCore
0x18b82e000 - 0x18b8befff FileProvider arm64  <77592354934f361685c61c42a08c7df2> /System/Library/Frameworks/FileProvider.framework/FileProvider
0x18b8bf000 - 0x18b9befff NLP arm64  <ea65fd7d7caa36d9a86d63180f9d6fce> /System/Library/PrivateFrameworks/NLP.framework/NLP
0x18b9bf000 - 0x18ba97fff ProofReader arm64  <cabbb8fe46ed32b8a300049347f46a88> /System/Library/PrivateFrameworks/ProofReader.framework/ProofReader
0x18ba98000 - 0x18baacfff libAccessibility.dylib arm64  <23641ce47f68337581c43ed279097e96> /usr/lib/libAccessibility.dylib
0x18baad000 - 0x18bf05fff libwebrtc.dylib arm64  <86637a5bac253f74a5a7fc4c04f0365b> /System/Library/PrivateFrameworks/WebCore.framework/Frameworks/libwebrtc.dylib
0x18bf06000 - 0x18bf65fff ContactsFoundation arm64  <bc5cc788458a33b592ecd8decd6e1f7e> /System/Library/PrivateFrameworks/ContactsFoundation.framework/ContactsFoundation
0x18bf66000 - 0x18d308fff WebCore arm64  <64cb5e60ad39394a9488d7ec006b2a74> /System/Library/PrivateFrameworks/WebCore.framework/WebCore
0x18d309000 - 0x18d47bfff WebKitLegacy arm64  <e23e83f01b9336859e1718b387460dc2> /System/Library/PrivateFrameworks/WebKitLegacy.framework/WebKitLegacy
0x18d47c000 - 0x18d4a4fff DataAccessExpress arm64  <425bac1cd08e300bb6604db52f6fb547> /System/Library/PrivateFrameworks/DataAccessExpress.framework/DataAccessExpress
0x18d4a5000 - 0x18d53cfff AddressBookLegacy arm64  <f79907fa02f6336baa67e5b305edc57f> /System/Library/PrivateFrameworks/AddressBookLegacy.framework/AddressBookLegacy
0x18d53d000 - 0x18d590fff ProtectedCloudStorage arm64  <ab7e3951e2db3534a09a4ad7435d759b> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/ProtectedCloudStorage
0x18d591000 - 0x18d5bdfff UserNotifications arm64  <c0ced430945d3345a7e4e5161c201d5c> /System/Library/Frameworks/UserNotifications.framework/UserNotifications
0x18d5be000 - 0x18d5c9fff AppleIDAuthSupport arm64  <27d452765548359b9b61725d1c5871c8> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/AppleIDAuthSupport
0x18d5ca000 - 0x18d617fff AuthKit arm64  <14ead1a5f5d53934ab09cc1d0506eaea> /System/Library/PrivateFrameworks/AuthKit.framework/AuthKit
0x18d618000 - 0x18d641fff DictionaryServices arm64  <1125d98486c73e41abbf071bfb356b20> /System/Library/PrivateFrameworks/DictionaryServices.framework/DictionaryServices
0x18d642000 - 0x18d694fff DocumentManager arm64  <3961561068023939b203fde9fe0be600> /System/Library/Frameworks/UIKit.framework/Frameworks/DocumentManager.framework/DocumentManager
0x18d695000 - 0x18e70afff UIKit arm64  <4708cf24f7c734219574cdeb8e3a0763> /System/Library/Frameworks/UIKit.framework/UIKit
0x18e70b000 - 0x18e71bfff DocumentManagerCore arm64  <74e3780bb01d316c81aca086950921c1> /System/Library/PrivateFrameworks/DocumentManagerCore.framework/DocumentManagerCore
0x18e71c000 - 0x18e71ffff HangTracer arm64  <45bc5c0ecbd631a2b975d07b453331fe> /System/Library/PrivateFrameworks/HangTracer.framework/HangTracer
0x18e720000 - 0x18e772fff PhysicsKit arm64  <ce758809dbbf3611a0811eacbc9141bb> /System/Library/PrivateFrameworks/PhysicsKit.framework/PhysicsKit
0x18e773000 - 0x18e775fff StudyLog arm64  <11266c7ac1f1367396ae3c48d4b25655> /System/Library/PrivateFrameworks/StudyLog.framework/StudyLog
0x18e776000 - 0x18e856fff UIFoundation arm64  <d165248616893548bc5345cc072557b6> /System/Library/PrivateFrameworks/UIFoundation.framework/UIFoundation
0x18e857000 - 0x18e962fff CloudKit arm64  <89ba646bfff53b97a85a3b50b989c352> /System/Library/Frameworks/CloudKit.framework/CloudKit
0x18e963000 - 0x18e963fff IntentsFoundation arm64  <6afe1d037833313485a2639410a33fd1> /System/Library/PrivateFrameworks/IntentsFoundation.framework/IntentsFoundation
0x18e964000 - 0x18ea2dfff Network arm64  <4bbb4fd713b13fce9d356ce7a5bec67f> /System/Library/PrivateFrameworks/Network.framework/Network
0x18ea2e000 - 0x18ec36fff Intents arm64  <6f6e387fe2a83507afa9d783857b7371> /System/Library/Frameworks/Intents.framework/Intents
0x18ec37000 - 0x18ec52fff libresolv.9.dylib arm64  <6112d40e403d357fbad3d1c5eece44c1> /usr/lib/libresolv.9.dylib
0x18ec53000 - 0x18ec55fff CoreDuetDebugLogging arm64  <2111519bcd4439708c05623b4e1d84ac> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/CoreDuetDebugLogging
0x18ec56000 - 0x18ec8afff libtidy.A.dylib arm64  <6ca9cfa0ea6e31e6be2882844b4e3882> /usr/lib/libtidy.A.dylib
0x18ec8b000 - 0x18edb2fff CoreDuet arm64  <d6f40e3387fe3492a1ccf211a9bc6bf9> /System/Library/PrivateFrameworks/CoreDuet.framework/CoreDuet
0x18edb3000 - 0x18edd1fff CoreDuetContext arm64  <f6e48ad0491b39caa3af0fb969a5c293> /System/Library/PrivateFrameworks/CoreDuetContext.framework/CoreDuetContext
0x18edd2000 - 0x18ede6fff CoreDuetDaemonProtocol arm64  <f99189deed7d36958dddbca1ab6321e4> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/CoreDuetDaemonProtocol
0x18ede7000 - 0x18ee52fff IMFoundation arm64  <5d62cd7090a23e7ab74789130e96a5dc> /System/Library/PrivateFrameworks/IMFoundation.framework/IMFoundation
0x18ee53000 - 0x18ee81fff vCard arm64  <617bfade5c6537c0967a7d32b4ed7ad5> /System/Library/PrivateFrameworks/vCard.framework/vCard
0x18ee82000 - 0x18ef89fff Contacts arm64  <078dde6797713223a520eb8ecc79d0b5> /System/Library/Frameworks/Contacts.framework/Contacts
0x18ef8a000 - 0x18ef8bfff DiagnosticLogCollection arm64  <4ba5c163e52a3bf8b3d42b2cd242d68c> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/DiagnosticLogCollection
0x18ef8c000 - 0x18ef8dfff Marco arm64  <58cd6bed2d16302bb84527a52e6aad4a> /System/Library/PrivateFrameworks/Marco.framework/Marco
0x18ef8e000 - 0x18ef94fff MessageProtection arm64  <eac29f93cc72332fabc75a7696ae29f0> /System/Library/PrivateFrameworks/MessageProtection.framework/MessageProtection
0x18ef95000 - 0x18f28dfff StoreServices arm64  <cd530f60cdd4384d8f6cfeb3c4dfc820> /System/Library/PrivateFrameworks/StoreServices.framework/StoreServices
0x18f28e000 - 0x18f2a6fff Engram arm64  <06ac3d820b1837429dbcc4afe23f057e> /System/Library/PrivateFrameworks/Engram.framework/Engram
0x18f2a7000 - 0x18f50dfff IDSFoundation arm64  <1b3cee6f88db3474bd7418f67e5039b3> /System/Library/PrivateFrameworks/IDSFoundation.framework/IDSFoundation
0x18f50e000 - 0x18f519fff CaptiveNetwork arm64  <7370ab9c9d19372694c32eddd151408b> /System/Library/PrivateFrameworks/CaptiveNetwork.framework/CaptiveNetwork
0x18f51a000 - 0x18f548fff EAP8021X arm64  <f011d0c978dc3371a68adbd963feae2c> /System/Library/PrivateFrameworks/EAP8021X.framework/EAP8021X
0x18f549000 - 0x18f583fff MobileWiFi arm64  <821b33e7c58132e887940e7a63f83c94> /System/Library/PrivateFrameworks/MobileWiFi.framework/MobileWiFi
0x18f584000 - 0x18f586fff OAuth arm64  <fa58137fc53d3ec7ab103b0ef0837308> /System/Library/PrivateFrameworks/OAuth.framework/OAuth
0x18f587000 - 0x18f589fff CommonAuth arm64  <ca5c8872bba93e9cbd0d22bfbe6f3f8d> /System/Library/PrivateFrameworks/CommonAuth.framework/CommonAuth
0x18f58a000 - 0x18f5f8fff Heimdal arm64  <e140358df24f3c048fc72a418ef7706f> /System/Library/PrivateFrameworks/Heimdal.framework/Heimdal
0x18f5f9000 - 0x18f622fff GSS arm64  <7356db1437d33b4eaae3181c2f930107> /System/Library/Frameworks/GSS.framework/GSS
0x18f623000 - 0x18f63afff ApplePushService arm64  <9f71334cb8273c719e7c48dd19e4ae15> /System/Library/PrivateFrameworks/ApplePushService.framework/ApplePushService
0x18f63b000 - 0x18f6d3fff AccountsDaemon arm64  <41d72f5376e53be993c062acb42ce5c7> /System/Library/PrivateFrameworks/AccountsDaemon.framework/AccountsDaemon
0x18f6d4000 - 0x18f6f2fff AppleIDSSOAuthentication arm64  <581b0aafe3af3f2297906d743f907e76> /System/Library/PrivateFrameworks/AppleIDSSOAuthentication.framework/AppleIDSSOAuthentication
0x18f6f3000 - 0x18f765fff AppleAccount arm64  <855aeb4d5acf304d837a233cdfd9b8d3> /System/Library/PrivateFrameworks/AppleAccount.framework/AppleAccount
0x18f766000 - 0x18f85cfff CoreUtils arm64  <6aef56c16f8e38cb84515ad30106d4d4> /System/Library/PrivateFrameworks/CoreUtils.framework/CoreUtils
0x18f85d000 - 0x18f976fff IDS arm64  <0a0ac8f0de78370c8a00166e8fe250ef> /System/Library/PrivateFrameworks/IDS.framework/IDS
0x18f977000 - 0x18f999fff MediaServices arm64  <76ac3ce527e231b0b3a523213156b10d> /System/Library/PrivateFrameworks/MediaServices.framework/MediaServices
0x18f99a000 - 0x18fac6fff MediaRemote arm64  <b1c783be5a2e3092a45991b2aa05ef67> /System/Library/PrivateFrameworks/MediaRemote.framework/MediaRemote
0x18fac7000 - 0x18faddfff UserManagement arm64  <083847fbe165363c90f54207b0398742> /System/Library/PrivateFrameworks/UserManagement.framework/UserManagement
0x18fade000 - 0x18faedfff MobileBluetooth arm64  <c70e58861e7c36909c7454485bbbe71a> /System/Library/PrivateFrameworks/MobileBluetooth.framework/MobileBluetooth
0x18faee000 - 0x18fb1efff Bom arm64  <cf0e2d0d73e43f8c860dbc67b44126f0> /System/Library/PrivateFrameworks/Bom.framework/Bom
0x18fb1f000 - 0x18fb23fff CommunicationsFilter arm64  <0eb89b9e7d093913b5bab2b13dcfcaf7> /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CommunicationsFilter
0x18fb24000 - 0x18fb49fff FTAWD arm64  <9ca76d840e9a3487a261d8b229f8d102> /System/Library/PrivateFrameworks/FTAWD.framework/FTAWD
0x18fb4a000 - 0x18fb9dfff FTServices arm64  <db7aee922bc739c4b5bec28ef22570bf> /System/Library/PrivateFrameworks/FTServices.framework/FTServices
0x18fb9e000 - 0x18fbf0fff WirelessProximity arm64  <9ec317a7f29c3fb2b221a56641660a49> /System/Library/PrivateFrameworks/WirelessProximity.framework/WirelessProximity
0x18fbf1000 - 0x18fbfbfff ProactiveEventTracker arm64  <6d6d7ae28f0b3888bfa092d1a6da05eb> /System/Library/PrivateFrameworks/ProactiveEventTracker.framework/ProactiveEventTracker
0x18fbfc000 - 0x18fc4dfff ChunkingLibrary arm64  <0b1fe58868c33c77827598bb2f7e3704> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/ChunkingLibrary
0x18fc4e000 - 0x18fc5afff libnetworkextension.dylib arm64  <9006f01a438e3a449246ff4cc12a2cbf> /usr/lib/libnetworkextension.dylib
0x18fc5b000 - 0x18fc7ffff AddressBook arm64  <96bdc1de5cbf3a1d9eb2b9ac302f8c2d> /System/Library/Frameworks/AddressBook.framework/AddressBook
0x190a65000 - 0x190bfafff NetworkExtension arm64  <e8f4c4267dbd3c8abe3cb1a09da44498> /System/Library/Frameworks/NetworkExtension.framework/NetworkExtension
0x190bfb000 - 0x190ffefff SiriTTS arm64  <c91d57bfc5933f958528458ee97438d4> /System/Library/PrivateFrameworks/SiriTTS.framework/SiriTTS
0x190fff000 - 0x191055fff SAObjects arm64  <1f945bf869973f1ba3e2b64772aa67bd> /System/Library/PrivateFrameworks/SAObjects.framework/SAObjects
0x191056000 - 0x191091fff VoiceServices arm64  <f1c82418152436a59c9369b9d74f7620> /System/Library/PrivateFrameworks/VoiceServices.framework/VoiceServices
0x191092000 - 0x1910c2fff GLKit arm64  <54d43e5b19763f6b9b4d1cae180f98ce> /System/Library/Frameworks/GLKit.framework/GLKit
0x1910c3000 - 0x19118efff AssistantServices arm64  <53995ad11bec37209d8863f586947303> /System/Library/PrivateFrameworks/AssistantServices.framework/AssistantServices
0x19118f000 - 0x191196fff AssetCacheServices arm64  <adfd92ff98e6319190950e96f0ee5f56> /System/Library/PrivateFrameworks/AssetCacheServices.framework/AssetCacheServices
0x191197000 - 0x191251fff NetworkServiceProxy arm64  <b14b04ac641e32428b9a27bfbf8f8b34> /System/Library/PrivateFrameworks/NetworkServiceProxy.framework/NetworkServiceProxy
0x191252000 - 0x191337fff MMCS arm64  <436a4cc8107135e1bf7dcd5ece3a7f2d> /System/Library/PrivateFrameworks/MMCS.framework/MMCS
0x191338000 - 0x191344fff BluetoothManager arm64  <146859b1bc3a35639cc7f30c4665c924> /System/Library/PrivateFrameworks/BluetoothManager.framework/BluetoothManager
0x191345000 - 0x1913b6fff CoreDAV arm64  <fbb700400b3d38d391a899f700803b6c> /System/Library/PrivateFrameworks/CoreDAV.framework/CoreDAV
0x1913b7000 - 0x1913ebfff iCalendar arm64  <ad5a551512623cf48595cc08db62d3c1> /System/Library/PrivateFrameworks/iCalendar.framework/iCalendar
0x1913ec000 - 0x1913fafff PersonaKit arm64  <6f86901935b8359892902f012e103688> /System/Library/PrivateFrameworks/PersonaKit.framework/PersonaKit
0x1913fb000 - 0x191454fff CalendarFoundation arm64  <9b14b75e15c23ea2bc5120de2d342f5a> /System/Library/PrivateFrameworks/CalendarFoundation.framework/CalendarFoundation
0x191455000 - 0x191482fff PhotosFormats arm64  <24c5b2b17a873d7b8268ff535c5900f5> /System/Library/PrivateFrameworks/PhotosFormats.framework/PhotosFormats
0x191483000 - 0x191520fff CalendarDatabase arm64  <9dc05665029c3b20aff0cd79f23ca7d5> /System/Library/PrivateFrameworks/CalendarDatabase.framework/CalendarDatabase
0x191521000 - 0x191572fff CalendarDaemon arm64  <d2b9ffeef42133239cff4fe768a7de7d> /System/Library/PrivateFrameworks/CalendarDaemon.framework/CalendarDaemon
0x191573000 - 0x191690fff CloudPhotoLibrary arm64  <f61c53afdcf63bd7b4c18c6387494c8c> /System/Library/PrivateFrameworks/CloudPhotoLibrary.framework/CloudPhotoLibrary
0x191691000 - 0x191774fff EventKit arm64  <dc1cdf2a82e038b7bc9ec91009bda7fc> /System/Library/Frameworks/EventKit.framework/EventKit
0x191775000 - 0x19179ffff AssetsLibraryServices arm64  <e577b1ae9a69377dbe0015e516a79b8b> /System/Library/PrivateFrameworks/AssetsLibraryServices.framework/AssetsLibraryServices
0x1917a0000 - 0x1917d4fff ACTFramework arm64  <33d60c9dc4e83b7d8a3ea8ce7101e478> /System/Library/PrivateFrameworks/ACTFramework.framework/ACTFramework
0x1917d5000 - 0x1917f5fff DCIMServices arm64  <7dfdea1f3a8b3365ac22ee756e3a03b3> /System/Library/PrivateFrameworks/DCIMServices.framework/DCIMServices
0x1917f6000 - 0x191930fff CoreMediaStream arm64  <22c987d700f23ca18b6f98309deada3d> /System/Library/PrivateFrameworks/CoreMediaStream.framework/CoreMediaStream
0x191931000 - 0x191938fff XPCKit arm64  <56667d7e63273716b7b11ee8092860c7> /System/Library/PrivateFrameworks/XPCKit.framework/XPCKit
0x191939000 - 0x191a1ffff CameraKit arm64  <a0483b576e203e38a7b23fc1966e0280> /System/Library/PrivateFrameworks/CameraKit.framework/CameraKit
0x191a20000 - 0x191a38fff CloudPhotoServices arm64  <92460c93e8d33e4eb912fbd9526310e6> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/CloudPhotoServices
0x191a39000 - 0x191a44fff CoreRecents arm64  <899a7e3f9ae137a2b50ca805641ebbc6> /System/Library/PrivateFrameworks/CoreRecents.framework/CoreRecents
0x191a45000 - 0x191a63fff MediaStream arm64  <68ebac415f953a1d875920fb59f7b64d> /System/Library/PrivateFrameworks/MediaStream.framework/MediaStream
0x191a64000 - 0x191e87fff PhotoLibraryServices arm64  <f10fd18c572d3192aaa30ecb3c3f29ab> /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/PhotoLibraryServices
0x191e88000 - 0x191ebefff PrototypeTools arm64  <6dc41b508b2f3fa5a9084ec38ed476f2> /System/Library/PrivateFrameworks/PrototypeTools.framework/PrototypeTools
0x191ebf000 - 0x191f4afff CoreSymbolication arm64  <2a7bed5d2dae3ac892d69efbefa822c3> /System/Library/PrivateFrameworks/CoreSymbolication.framework/CoreSymbolication
0x191f4b000 - 0x19206efff SearchFoundation arm64  <eb1897e24eaf39cbab29b4c99b465490> /System/Library/PrivateFrameworks/SearchFoundation.framework/SearchFoundation
0x19206f000 - 0x192075fff IncomingCallFilter arm64  <c493ea1b15b6320d92e8805bb84d5cc0> /System/Library/PrivateFrameworks/IncomingCallFilter.framework/IncomingCallFilter
0x192076000 - 0x19211efff iTunesStore arm64  <63a81dfaeade36eab06b4990959debed> /System/Library/PrivateFrameworks/iTunesStore.framework/iTunesStore
0x19211f000 - 0x192125fff libtzupdate.dylib arm64  <3ccb5e11bb583b818d3dd63d5f50adb1> /usr/lib/libtzupdate.dylib
0x192126000 - 0x19228bfff Preferences arm64  <1dd337fc1c713b9da43c1e8c83106459> /System/Library/PrivateFrameworks/Preferences.framework/Preferences
0x19228c000 - 0x192293fff CoreTime arm64  <cdc1dba602ff37dca9c2c9d7dcfac832> /System/Library/PrivateFrameworks/CoreTime.framework/CoreTime
0x192294000 - 0x1923fcfff CVML arm64  <096ff2ecd5b338e8a6947148c5aad14f> /System/Library/PrivateFrameworks/CVML.framework/CVML
0x1923fd000 - 0x192449fff CoreAppleCVA arm64  <d939c1b9c6a33adaa0fc8e4c54e3f27e> /System/Library/PrivateFrameworks/CoreAppleCVA.framework/CoreAppleCVA
0x19244a000 - 0x192480fff DifferentialPrivacy arm64  <33e1715d78e83ddb8049fd4b96e99f19> /System/Library/PrivateFrameworks/DifferentialPrivacy.framework/DifferentialPrivacy
0x192481000 - 0x1925e4fff AppleCVA arm64  <881a35d4318d3afa9b1ff60d49499577> /System/Library/PrivateFrameworks/AppleCVA.framework/AppleCVA
0x1925e5000 - 0x192680fff Montreal arm64  <34664c28ec733972aeb53ddc8499cbd6> /System/Library/PrivateFrameworks/Montreal.framework/Montreal
0x192681000 - 0x192859fff Espresso arm64  <f40931cf781b30d0ae541fc08d84259d> /System/Library/PrivateFrameworks/Espresso.framework/Espresso
0x19285e000 - 0x1929b0fff Photos arm64  <c906aedc92f03b09a44498bf50aaad74> /System/Library/Frameworks/Photos.framework/Photos
0x1929bd000 - 0x192b6afff CoreML arm64  <bb1b5481170d33819cc0269bdc82e0d9> /System/Library/Frameworks/CoreML.framework/CoreML
0x192b6b000 - 0x192b6ffff CoreOptimization arm64  <14c64d1647493d73b9d47a245089b5d8> /System/Library/PrivateFrameworks/CoreOptimization.framework/CoreOptimization
0x192b70000 - 0x192baafff SafariCore arm64  <369a86590f9739f288be6313ca36d96e> /System/Library/PrivateFrameworks/SafariCore.framework/SafariCore
0x192bab000 - 0x192c05fff CorePrediction arm64  <c614db07e6dd3bcea8fea8a5611918b3> /System/Library/PrivateFrameworks/CorePrediction.framework/CorePrediction
0x192c06000 - 0x192d02fff Navigation arm64  <c4898f49b66734578d0b6d79b3948866> /System/Library/PrivateFrameworks/Navigation.framework/Navigation
0x192d03000 - 0x192d1bfff ContactsDonation arm64  <555b82bf7c2b3c44b1baae92aafe806e> /System/Library/PrivateFrameworks/ContactsDonation.framework/ContactsDonation
0x192d1c000 - 0x192d48fff Futhark arm64  <6765c418aaa63b27a4a6df34123c7e0d> /System/Library/PrivateFrameworks/Futhark.framework/Futhark
0x192d8c000 - 0x192ddefff ToneLibrary arm64  <0340ea13f43937809d7e52cb06be94ae> /System/Library/PrivateFrameworks/ToneLibrary.framework/ToneLibrary
0x192ddf000 - 0x192df1fff BaseBoardUI arm64  <5913298e3ecc3fdaaf3e9a3ce4fe4f05> /System/Library/PrivateFrameworks/BaseBoardUI.framework/BaseBoardUI
0x192df2000 - 0x192e49fff ContactsUICore arm64  <db13d69fbe0137338600e254c85ac15f> /System/Library/PrivateFrameworks/ContactsUICore.framework/ContactsUICore
0x192e4a000 - 0x192fadfff ContactsUI arm64  <21ba04bf5831317f8b5e5af4e5d6ca66> /System/Library/Frameworks/ContactsUI.framework/ContactsUI
0x192fae000 - 0x193084fff CorePDF arm64  <e5e14506972e3db6984aae5894fdcde5> /System/Library/PrivateFrameworks/CorePDF.framework/CorePDF
0x193085000 - 0x1932e0fff Vision arm64  <5f88c06f3ac0327586728dfec97970ef> /System/Library/Frameworks/Vision.framework/Vision
0x1932e1000 - 0x19368efff WebKit arm64  <2224640f7c733d3b86b42f44d801d9b2> /System/Library/Frameworks/WebKit.framework/WebKit
0x19368f000 - 0x193748fff BulletinBoard arm64  <e34f632990d73fc8ba12d8c56c74f408> /System/Library/PrivateFrameworks/BulletinBoard.framework/BulletinBoard
0x193749000 - 0x19374efff ConstantClasses arm64  <012de7d5df2b332bb8b16617404bdb71> /System/Library/PrivateFrameworks/ConstantClasses.framework/ConstantClasses
0x19374f000 - 0x193757fff CertUI arm64  <7eac85579f81311f997c85a6e3d0ddd7> /System/Library/PrivateFrameworks/CertUI.framework/CertUI
0x193758000 - 0x19379afff AXRuntime arm64  <031488f699093e72928149d0d86fdc85> /System/Library/PrivateFrameworks/AXRuntime.framework/AXRuntime
0x19379b000 - 0x1937d2fff ScreenReaderCore arm64  <6dca0b1429c9342e8a6b26e523e0fef7> /System/Library/PrivateFrameworks/ScreenReaderCore.framework/ScreenReaderCore
0x1937d3000 - 0x1937f6fff TextToSpeech arm64  <771628a327c83f43b2b21a18527c8f26> /System/Library/PrivateFrameworks/TextToSpeech.framework/TextToSpeech
0x1937f7000 - 0x19383dfff CoreMIDI arm64  <a37dc2e94fed3169836df3683b64c7eb> /System/Library/Frameworks/CoreMIDI.framework/CoreMIDI
0x19383e000 - 0x1938dafff MediaPlatform arm64  <9eeb6a5ba91c3435bfabb904a15b8b26> /System/Library/PrivateFrameworks/MediaPlatform.framework/MediaPlatform
0x1938db000 - 0x19393afff WebBookmarks arm64  <b73c77f16c4c367faa878ea11276ff7d> /System/Library/PrivateFrameworks/WebBookmarks.framework/WebBookmarks
0x19393b000 - 0x193941fff DAAPKit arm64  <94f8ec869c4034779031bedf4c31db52> /System/Library/PrivateFrameworks/DAAPKit.framework/DAAPKit
0x193942000 - 0x193944fff libAXSafeCategoryBundle.dylib arm64  <9255d017aa7d3911905645ebd0df0731> /usr/lib/libAXSafeCategoryBundle.dylib
0x193945000 - 0x19394ffff libAXSpeechManager.dylib arm64  <c1a9b205b0f93694a7e5beb21cbf8460> /usr/lib/libAXSpeechManager.dylib
0x193950000 - 0x193a32fff AccessibilityUtilities arm64  <a473b8b0af5933e18b4632ef24fde6e3> /System/Library/PrivateFrameworks/AccessibilityUtilities.framework/AccessibilityUtilities
0x193a33000 - 0x193d0bfff MediaLibraryCore arm64  <b4cc309be3513471999aef9279d4743c> /System/Library/PrivateFrameworks/MediaLibraryCore.framework/MediaLibraryCore
0x193d0c000 - 0x193d0cfff AdSupport arm64  <85154ac5d64c342ab868ff332e90e504> /System/Library/Frameworks/AdSupport.framework/AdSupport
0x193d0d000 - 0x193f8bfff MusicLibrary arm64  <bfea1081897330919b884ac1359d5dee> /System/Library/PrivateFrameworks/MusicLibrary.framework/MusicLibrary
0x193f8c000 - 0x194612fff VectorKit arm64  <180c464177913480b8871c39a51ce386> /System/Library/PrivateFrameworks/VectorKit.framework/VectorKit
0x194613000 - 0x19484ffff MapKit arm64  <138fd03bf9623a028579ffb6b14b69b0> /System/Library/Frameworks/MapKit.framework/MapKit
0x194850000 - 0x1949bafff iTunesCloud arm64  <8c934a63b54f3342aca75ec524f36d28> /System/Library/PrivateFrameworks/iTunesCloud.framework/iTunesCloud
0x1949bb000 - 0x194a5bfff HomeSharing arm64  <ef4d1fddd2563fa190f26c0156fd8cc9> /System/Library/PrivateFrameworks/HomeSharing.framework/HomeSharing
0x194a5c000 - 0x194ad1fff WebInspector arm64  <7b9898c141c53098b7ad263d1f364bad> /System/Library/PrivateFrameworks/WebInspector.framework/WebInspector
0x194ad2000 - 0x194bb9fff ITMLKit arm64  <d2edb026e3a830c39098a26a61454861> /System/Library/PrivateFrameworks/ITMLKit.framework/ITMLKit
0x194bca000 - 0x194ffffff MediaPlayer arm64  <95ed93ac0daa3168bd55830e92c10621> /System/Library/Frameworks/MediaPlayer.framework/MediaPlayer
0x195026000 - 0x19502cfff EmailAddressing arm64  <acc6b1ef0cc8378f81dbd4e70fc7e523> /System/Library/PrivateFrameworks/EmailAddressing.framework/EmailAddressing
0x19502d000 - 0x19502ffff MessageSupport arm64  <4d42284011923220b44f44626e9a9acb> /System/Library/PrivateFrameworks/MessageSupport.framework/MessageSupport
0x195030000 - 0x195032fff InternationalTextSearch arm64  <3ddae82df6633d39a990b656d6a01cd9> /System/Library/PrivateFrameworks/InternationalTextSearch.framework/InternationalTextSearch
0x195033000 - 0x19508dfff MIME arm64  <e0722c6c58e73b9b97ae2d5223075125> /System/Library/PrivateFrameworks/MIME.framework/MIME
0x19508e000 - 0x1950bdfff ProactiveSupport arm64  <cb67c8bf3c3a32bd929027b4d106c677> /System/Library/PrivateFrameworks/ProactiveSupport.framework/ProactiveSupport
0x1950be000 - 0x1950f6fff Notes arm64  <f4516e01056d3de9b42908b7a37379a2> /System/Library/PrivateFrameworks/Notes.framework/Notes
0x1950f7000 - 0x1951a7fff TelephonyUtilities arm64  <cb84815cdbab39dfaed889234e55e579> /System/Library/PrivateFrameworks/TelephonyUtilities.framework/TelephonyUtilities
0x1951a8000 - 0x1951e2fff CalendarUIKit arm64  <5bcc1e42d2fa342984e05a7e33d536a0> /System/Library/PrivateFrameworks/CalendarUIKit.framework/CalendarUIKit
0x1951e3000 - 0x1951fafff AccessibilityUIUtilities arm64  <da2bb94942f93a9ca8f0f132025d8e6e> /System/Library/PrivateFrameworks/Accessibility.framework/Frameworks/AccessibilityUIUtilities.framework/AccessibilityUIUtilities
0x1951fb000 - 0x195256fff DataAccess arm64  <7b1bbfa75a8a3a3b9a143575e12d734a> /System/Library/PrivateFrameworks/DataAccess.framework/DataAccess
0x195257000 - 0x19526afff AssetsLibrary arm64  <72e547bd283a3408802e9632d376bcf2> /System/Library/Frameworks/AssetsLibrary.framework/AssetsLibrary
0x19526b000 - 0x195449fff EventKitUI arm64  <80ae00c94d293b488e069d54df184712> /System/Library/Frameworks/EventKitUI.framework/EventKitUI
0x19544a000 - 0x1954a5fff AXMediaUtilities arm64  <35f1eedb9c7d307d8b7f8d6311a86eb6> /System/Library/PrivateFrameworks/AXMediaUtilities.framework/AXMediaUtilities
0x1954a6000 - 0x195519fff UIAccessibility arm64  <169220ecc20f397dbb84d18baa185a5b> /System/Library/PrivateFrameworks/UIAccessibility.framework/UIAccessibility
0x195535000 - 0x19553bfff SearchToSharePredictions arm64  <ffa381647ab13d919330337a424ef7c0> /System/Library/PrivateFrameworks/SearchToSharePredictions.framework/SearchToSharePredictions
0x19553c000 - 0x1955ddfff Social arm64  <6a4cf88de313334287a0f23ed2551626> /System/Library/Frameworks/Social.framework/Social
0x19566f000 - 0x195680fff CoreFollowUp arm64  <952561439984357fa986844dc3bc1e51> /System/Library/PrivateFrameworks/CoreFollowUp.framework/CoreFollowUp
0x195681000 - 0x1956f0fff CoreSuggestions arm64  <e983261fdcb2366998de81e0bec7eac9> /System/Library/PrivateFrameworks/CoreSuggestions.framework/CoreSuggestions
0x1956f1000 - 0x195701fff MailServices arm64  <71a796c3a45638ca9a9f45b489b68375> /System/Library/PrivateFrameworks/MailServices.framework/MailServices
0x195702000 - 0x195797fff CoreRecognition arm64  <d23a0bfbd6563c23adab8536917f095f> /System/Library/PrivateFrameworks/CoreRecognition.framework/CoreRecognition
0x195798000 - 0x1957b2fff MailSupport arm64  <61503d74ee0336c3b64cd71052ff06cc> /System/Library/PrivateFrameworks/MailSupport.framework/MailSupport
0x1957b3000 - 0x195901fff Message arm64  <94e02018b75f3c8ab9cf3997c4b940c4> /System/Library/PrivateFrameworks/Message.framework/Message
0x195902000 - 0x195b24fff libmecabra.dylib arm64  <e6f4c66ce29f35a3b7b3489070807782> /usr/lib/libmecabra.dylib
0x195b25000 - 0x195bbffff CoreParsec arm64  <8d450c0c6d9f3b4c866b104d7a5c29ef> /System/Library/PrivateFrameworks/CoreParsec.framework/CoreParsec
0x195bf0000 - 0x195c21fff SharedUtils arm64  <c37cb0927cb7391daf30ba2320e6f6bf> /System/Library/Frameworks/LocalAuthentication.framework/Support/SharedUtils.framework/SharedUtils
0x195c22000 - 0x195c5dfff ContactsAutocomplete arm64  <f512d7e1b23a3ce69149503623683ad6> /System/Library/PrivateFrameworks/ContactsAutocomplete.framework/ContactsAutocomplete
0x195c5e000 - 0x195d22fff VideoSubscriberAccount arm64  <dece6429ff253d9ca97997cc25bfe9e4> /System/Library/Frameworks/VideoSubscriberAccount.framework/VideoSubscriberAccount
0x195d23000 - 0x195d54fff Pegasus arm64  <4bddc2d23cb732e38945ad29f87155ba> /System/Library/PrivateFrameworks/Pegasus.framework/Pegasus
0x195d55000 - 0x195dd5fff AVKit arm64  <57fe47c42f35374494e53647cfade740> /System/Library/Frameworks/AVKit.framework/AVKit
0x195dfa000 - 0x195dfdfff FTClientServices arm64  <bd7a1e7c96b93b4a8408bd72686ebaca> /System/Library/PrivateFrameworks/FTClientServices.framework/FTClientServices
0x195dfe000 - 0x195e11fff SharedWebCredentials arm64  <1bacca3a6a2c34e3a043ab2cb94e6075> /System/Library/PrivateFrameworks/SharedWebCredentials.framework/SharedWebCredentials
0x195e13000 - 0x195e16fff SafariFoundation arm64  <fd3570619a00382fb6d1beb8b242831c> /System/Library/PrivateFrameworks/SafariFoundation.framework/SafariFoundation
0x195f9f000 - 0x195fb5fff LocalAuthentication arm64  <6707b3ba83e33cc0ab014e5f6096ee69> /System/Library/Frameworks/LocalAuthentication.framework/LocalAuthentication
0x195fb6000 - 0x195fb8fff ParsecSubscriptionServiceSupport arm64  <386fb663c4e43b91aa87bb11766f4bab> /System/Library/PrivateFrameworks/ParsecSubscriptionServiceSupport.framework/ParsecSubscriptionServiceSupport
0x196060000 - 0x196078fff CoreInterest arm64  <f20a19ef2bdf3746aab8165349b00c80> /System/Library/PrivateFrameworks/CoreInterest.framework/CoreInterest
0x196079000 - 0x1962d7fff SafariShared arm64  <79ba256ab93d3a6cafcce49bdc4057ff> /System/Library/PrivateFrameworks/SafariShared.framework/SafariShared
0x1962d8000 - 0x196312fff WebUI arm64  <9475008be6bf3cf28224aca8393a9ab1> /System/Library/PrivateFrameworks/WebUI.framework/WebUI
0x196313000 - 0x19631efff SetupAssistantSupport arm64  <dc2779c6c53039919cbee64c6d2acc4a> /System/Library/PrivateFrameworks/SetupAssistantSupport.framework/SetupAssistantSupport
0x19631f000 - 0x196346fff SetupAssistant arm64  <68eff9f582233002aea9603d3f24e51b> /System/Library/PrivateFrameworks/SetupAssistant.framework/SetupAssistant
0x196394000 - 0x19639dfff MobileStorage arm64  <e6ad79dd02f43c7fa4510032fd00b295> /System/Library/PrivateFrameworks/MobileStorage.framework/MobileStorage
0x19639e000 - 0x1963e0fff ContentIndex arm64  <6c63191321c73daf8a7b9ce614fbfda2> /System/Library/PrivateFrameworks/ContentIndex.framework/ContentIndex
0x1963e1000 - 0x1966d4fff ImageCapture arm64  <32019287f30b3dea8571c29553a991bb> /System/Library/PrivateFrameworks/ImageCapture.framework/ImageCapture
0x1966d5000 - 0x1968a4fff NeutrinoCore arm64  <1ee6eff2b35832fd9ad4abf3bfc03fc6> /System/Library/PrivateFrameworks/NeutrinoCore.framework/NeutrinoCore
0x1968a5000 - 0x1968bbfff iPhotoMigrationSupport arm64  <45f0def82e113794bdcf403df3ff1346> /System/Library/PrivateFrameworks/iPhotoMigrationSupport.framework/iPhotoMigrationSupport
0x1968bc000 - 0x1968cdfff DiagnosticExtensions arm64  <2e54c5af671d332d95d2c4bcacf1c08f> /System/Library/PrivateFrameworks/DiagnosticExtensions.framework/DiagnosticExtensions
0x196bcd000 - 0x196c64fff PhotoLibrary arm64  <d780d3adad1b3e9faa7934f9a400f27b> /System/Library/PrivateFrameworks/PhotoLibrary.framework/PhotoLibrary
0x196c65000 - 0x196fb3fff PhotosUICore arm64  <b6ca3b98bd703da2aa67a6106b597f50> /System/Library/PrivateFrameworks/PhotosUICore.framework/PhotosUICore
0x196fea000 - 0x197003fff CoreSDB arm64  <f38b63830be13af983ca9f232bb57cd2> /System/Library/PrivateFrameworks/CoreSDB.framework/CoreSDB
0x197004000 - 0x197059fff IMSharedUtilities arm64  <15fa14bcc7cc35ea8218f75b0709cf90> /System/Library/PrivateFrameworks/IMSharedUtilities.framework/IMSharedUtilities
0x19705a000 - 0x197060fff LinguisticData arm64  <6896b00291a7366aa4951980043996ee> /System/Library/PrivateFrameworks/LinguisticData.framework/LinguisticData
0x197061000 - 0x197078fff NeutrinoKit arm64  <d8659956dfde38dab2705f09c0731d97> /System/Library/PrivateFrameworks/NeutrinoKit.framework/NeutrinoKit
0x197079000 - 0x197103fff PhotoEditSupport arm64  <73cfccd19c673ec3951aafbdd52723af> /System/Library/PrivateFrameworks/PhotoEditSupport.framework/PhotoEditSupport
0x197104000 - 0x197116fff SiriTasks arm64  <d9287811291d3ee986c5f69ccb9cc287> /System/Library/PrivateFrameworks/SiriTasks.framework/SiriTasks
0x197117000 - 0x197537fff PhotosUI arm64  <e1edb5358a643c48a8119f1f6031d0db> /System/Library/Frameworks/PhotosUI.framework/PhotosUI
0x1976ce000 - 0x1976e9fff EmojiFoundation arm64  <5aec0b86aa1734f6a801d67d06e14bde> /System/Library/PrivateFrameworks/EmojiFoundation.framework/EmojiFoundation
0x1976ea000 - 0x1977fcfff IMDPersistence arm64  <63d6f4a314183e2cb8ded7a5edcde1da> /System/Library/PrivateFrameworks/IMDPersistence.framework/IMDPersistence
0x1977fd000 - 0x197817fff MetalKit arm64  <6bbf623d769731008277eb593048ef67> /System/Library/Frameworks/MetalKit.framework/MetalKit
0x197818000 - 0x197839fff GenerationalStorage arm64  <e9b59e80f75f3f7ea25bb4c6dcb0f9e5> /System/Library/PrivateFrameworks/GenerationalStorage.framework/GenerationalStorage
0x197c7a000 - 0x197d48fff CoreHandwriting arm64  <fec70ac49a9031668c834625f2ebbd71> /System/Library/PrivateFrameworks/CoreHandwriting.framework/CoreHandwriting
0x197eac000 - 0x197eb4fff AddressBookUI arm64  <89c59c5837833e7ba81c8f83216b4b0a> /System/Library/Frameworks/AddressBookUI.framework/AddressBookUI
0x1982e5000 - 0x19840ffff PencilKit arm64  <daa0a2b164393ea1b7afc2f2162508fc> /System/Library/PrivateFrameworks/PencilKit.framework/PencilKit
0x198410000 - 0x19842dfff QuickLookThumbnailing arm64  <c3aa7cdf5cd032d88cf4ea3fa46bff5f> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/QuickLookThumbnailing
0x19842e000 - 0x1984e9fff PDFKit arm64  <e654fe55ab1a3c229aec449ea43c93d7> /System/Library/Frameworks/PDFKit.framework/PDFKit
0x1984ea000 - 0x198616fff AnnotationKit arm64  <1d7e589ba2e437558e796638e126538e> /System/Library/PrivateFrameworks/AnnotationKit.framework/AnnotationKit
0x198617000 - 0x1987b6fff IMCore arm64  <cada84d5701d30a5b9d2ebdd32c3e2ce> /System/Library/PrivateFrameworks/IMCore.framework/IMCore
0x1987cf000 - 0x198815fff Pasteboard arm64  <7e63b70aa500356194039f9e90ba578d> /System/Library/PrivateFrameworks/Pasteboard.framework/Pasteboard
0x198836000 - 0x198866fff MarkupUI arm64  <3ec3c979d1cb307291929de813ccefa0> /System/Library/PrivateFrameworks/MarkupUI.framework/MarkupUI
0x198889000 - 0x198942fff QuickLook arm64  <f7491f2cd30d32d484fd2e662b4e88c5> /System/Library/Frameworks/QuickLook.framework/QuickLook
0x198a28000 - 0x198a6efff SafariSafeBrowsing arm64  <577597e8a76337d4903438c56f6b1a40> /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/SafariSafeBrowsing
0x198a8d000 - 0x198b93fff SafariServices arm64  <8047e3215f7837b5af6314518a44be0b> /System/Library/Frameworks/SafariServices.framework/SafariServices
0x198f0f000 - 0x199009fff MessageUI arm64  <2065f804cdaa3b28babfc7b3bc7d7507> /System/Library/Frameworks/MessageUI.framework/MessageUI
0x19a4b4000 - 0x19a508fff CallKit arm64  <0b8c563409c13f64aeeecaf31843abfe> /System/Library/Frameworks/CallKit.framework/CallKit
0x19a565000 - 0x19a5c1fff IMAVCore arm64  <d9bae2136c1f342c89f0b03efaf6b2da> /System/Library/PrivateFrameworks/IMAVCore.framework/IMAVCore
0x19cdbe000 - 0x19cde2fff AppSupportUI arm64  <d2aa3b3a4ce3315e8e5cbc923d98f51c> /System/Library/PrivateFrameworks/AppSupportUI.framework/AppSupportUI
0x19daaa000 - 0x19dbfefff libGLProgrammability.dylib arm64  <a2417e0e38bc351bb72a4ffd02bc93c7> /System/Library/Frameworks/OpenGLES.framework/libGLProgrammability.dylib
0x19edf7000 - 0x19edfafff AGXCompilerConnection arm64  <f57bbdbd127c321cb657bbdcc08339d2> /System/Library/PrivateFrameworks/AGXCompilerConnection.framework/AGXCompilerConnection
0x19f3ef000 - 0x19f3f8fff libGPUSupportMercury.dylib arm64  <19a2e9f2ad9a3e709099416d5ef7cdc8> /System/Library/PrivateFrameworks/GPUSupport.framework/libGPUSupportMercury.dylib
0x1a322d000 - 0x1a34e1fff RawCamera arm64  <6a57a44279933303877d6b753a99568e> /System/Library/CoreServices/RawCamera.bundle/RawCamera
0x1a34f9000 - 0x1a357efff AGXGLDriver arm64  <c343914b2da134c0bb365ede83a47c90> /System/Library/Extensions/AGXGLDriver.bundle/AGXGLDriver
0x1a3802000 - 0x1a3816fff libCGInterfaces.dylib arm64  <dc01f8416b033dcfb1dbbb7f40777e83> /System/Library/Frameworks/Accelerate.framework/Frameworks/vImage.framework/Libraries/libCGInterfaces.dylib
0x1a456f000 - 0x1a4651fff GLEngine arm64  <807ae232d0753aebbcf9e25a965fa740> /System/Library/Frameworks/OpenGLES.framework/GLEngine.bundle/GLEngine
0x1a5c74000 - 0x1a5c9bfff CoreServicesInternal arm64  <60e1e8af6f4433d4a462ac72f72cc4f8> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/CoreServicesInternal
0x1a624d000 - 0x1a625efff libGSFontCache.dylib arm64  <d4088b263704312cbfbef3c0e8c26eb8> /System/Library/PrivateFrameworks/FontServices.framework/libGSFontCache.dylib
0x1a625f000 - 0x1a6291fff libTrueTypeScaler.dylib arm64  <63964522206d31ca9d7f5b9b78227abc> /System/Library/PrivateFrameworks/FontServices.framework/libTrueTypeScaler.dylib
0x1a79a0000 - 0x1a79a3fff InternationalSupport arm64  <6efcd0e042783733ac24282e37617085> /System/Library/PrivateFrameworks/InternationalSupport.framework/InternationalSupport
0x1a943e000 - 0x1a9449fff SyncedDefaults arm64  <1b41a53494a13417a242c60603f916a5> /System/Library/PrivateFrameworks/SyncedDefaults.framework/SyncedDefaults
0x1a9465000 - 0x1a946afff TextInputUI arm64  <87fa166bc057346dbbf819169cbe6cbe> /System/Library/PrivateFrameworks/TextInputUI.framework/TextInputUI
0x1ab411000 - 0x1ab442fff libclosured.dylib arm64  <56e1a40175843bda9c860bdbbcf1b0b5> /usr/lib/closure/libclosured.dylib
EOF
Nicholas-Furness
Thanks for that.
This is an issue that we've fixed in version 100.
However, that doesn't really help you with version 10.2.5. Are you considering updating to the current Runtime SDK (version 100.x)?
