Cocoapod podspec with ArcGIS Runtime dependency
2013
11-01-2016 01:53 PM
PeterSchuette
I am trying to write a Framework with an ArcGIS dependency.
The podspec fails inspection with the message:
- ERROR | [iOS] unknown: Encountered an unknown error (The 'Pods-App' target has transitive dependencies that include static binaries: (/**/CocoaPods/Lint/Pods/ArcGIS-Runtime-SDK-iOS/ArcGIS.framework)) during validation.
for this line:
Pod::Spec.new do |s|
  s.dependency 'ArcGIS-Runtime-SDK-iOS'
end
Is there a documented method of achieving what I have described? If not, has anyone in the community successfully built their own framework that makes use of ArcGIS and is distributed via CocoaPods?
YueWu1
by Esri Regular Contributor
Not too sure about this error message... However, found this thread on stackoverflow: ios - The 'Pods-App' target has transitive dependencies that include static binaries when installing...  has a similar error message that you mentioned from cocoapods.
There is a new cocopods thread in geonet recently talks about how to download: installing Quartz SDK Beta 3 using CocoaPods
We do have an old blog talks about cocoaPods: Installation for ArcGIS Runtime SDK for iOS with CocoaPods | Support Services Blog
AlexisBarat
Hey,
I've got the same problem. Did you find a solution ?
