Callout not show!
3697
10-27-2014 03:02 PM
MauricioSalazar
Hi, i try to show a callout from the geodatabase runtime content generated in Arcmap 10.2.1, iOS 7.0
but not show nothing, i have enabled gestureRecognizer in the MapView.
My code is this:
- (void)viewDidLoad
    docDir = [NSSearchPathForDirectoriesInDomains(NSDocumentDirectory, NSUserDomainMask, YES) objectAtIndex:0];
    NSString *PathGDB= [NSString stringWithFormat:@"%@/Mapas/data/app_navegacion.geodatabase",docDir];
    NSError* __autoreleasing ErrorGDB;
    AGSGDBGeodatabase *gdb =[ [AGSGDBGeodatabase alloc] initWithPath:PathGDB error:&ErrorGDB];
    localFeatureTable = [[gdb featureTables] objectAtIndex:0];
    localFeatureTableLayer = [[AGSFeatureTableLayer alloc] initWithFeatureTable:localFeatureTable];
    localFeatureTableLayer.delegate = self;
    localFeatureTableLayer.allowCallout = YES;
-(BOOL)callout:(AGSCallout *)callout willShowForFeature:(id<AGSFeature>)feature layer:(AGSLayer<AGSHitTestable> *)layer mapPoint:(AGSPoint *)mapPoint {
  self.mapView.callout.title = (NSString*)[feature attributeForKey:@"TextString"];
  self.mapView.callout.detail =(NSString*)[feature attributeForKey:@"FontName"];
  return YES;
Thanks.
by Anonymous User
Not applicable
When you add a breakpoint for this line:
is that line called when you tap at a feature?
If not, there is another layer or interaction with the map that is grabbing that event.
