ArcGIS SDK in IOS devices.
2114
05-07-2024 04:28 AM
JyoshnaRani
Which SDK can be use for ArcGIS maps in IOS devices "ArcGIS Maps SDK for Swift" or "ArcGIS Runtime SDK for iOS", and what is the different between these SDKs.
Tags (4)
Ting
by Esri Regular Contributor
To add to David's comment, ArcGIS Runtime SDK for iOS is using UIKit, while ArcGIS Maps SDK for Swift is using SwiftUI.
DavidFeinzimer
Hi @JyoshnaRani, thanks for reaching out. Either of the two SDKs can target iOS devices but ArcGIS Maps SDK for Swift replaces ArcGIS Runtime SDK for iOS. The iOS SDK is under long-term support and will only receive bug fixes and minor updates moving forward. The Swift SDK on the other hand is under active development and users can expect regular updates. Developers using the iOS SDK could write apps in either Objective-C or Swift. On the other hand, the Swift SDK is to be used solely with Swift and makes use of the language's latest features.
Overall, for new applicationsArcGIS Maps SDK for Swift is the recommended choice.
Ting
JyoshnaRani
Thank you @Ting and @DavidFeinzimer. 🙂
